Hi @deinon,
You are welcome.
That is because your operating system is caching the ip address of cdmon so it is using it instead of the new ip address pointing to cloudflare.
If you are using windows, open a command line and execute this command:
nslookup wondersinmotion.com
If you see 46.16.61.114
then your operating system is caching the old ip. You could open a cmd (as administrator) and type this command ipconfig /flushdns
so the dns cache will be removed and if you try again the nslookup
command you will see the new ips pointing to cloudflare.
But I can confirm it is working:
Connecting to www.wondersinmotion.com
using https:
curl -4IL https://www.wondersinmotion.com/test
HTTP/2 301
date: Thu, 10 May 2018 14:59:16 GMT
cache-control: max-age=3600
expires: Thu, 10 May 2018 15:59:16 GMT
expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
server: cloudflare
cf-ray: 418d44cbfe889ce4-AMS
Date: Thu, 10 May 2018 14:59:16 GMT
Server: Apache
Vary: Accept-Encoding
HTTP/1.1 200 OK
Server: Apache
X-Pingback: https://www.davidhiram.com/wondersinmotion/xmlrpc.php
Link: <https://www.davidhiram.com/wondersinmotion/wp-json/>; rel="https://api.w.org/"
Link: <https://www.davidhiram.com/wondersinmotion/>; rel=shortlink
Checking the certificate served by www.wondersinmotion.com
openssl s_client -connect wondersinmotion.com:443 -servername wondersinmotion.com </dev/null 2>/dev/null | openssl x509 -noout -text | grep wondersinmotion
DNS:sni164182.cloudflaressl.com, DNS:*.33kbcp.com, DNS:*.380992.com, DNS:*.arlingtonhighlands.com, DNS:*.avapelletier.tk, DNS:*.btchaber.com, DNS:*.centroybor.com, DNS:*.coinkolik.com, DNS:*.crowbase.org, DNS:*.distancebetweencities.net, DNS:*.distancy.com, DNS:*.dualarinsirri.com, DNS:*.evdennakliyateve.com, DNS:*.galvaniz.co, DNS:*.golgio.org, DNS:*.industrykhcnxb.ga, DNS:*.joshsreview-d.ga, DNS:*.meredithli.tk, DNS:*.mytownsquarelasvegas.com, DNS:*.nakliyatplatformu.com.tr, DNS:*.necessy.com, DNS:*.neyya.com, DNS:*.nlatestpdf.gq, DNS:*.osexandgodfilm.ga, DNS:*.paddockshops.com, DNS:*.paribu.io, DNS:*.paribu.xyz, DNS:*.postakoduara.com, DNS:*.sierragatehomes.ca, DNS:*.tickettapp2.com, DNS:*.ucnokta.org, DNS:*.whighbindersmovie.ml, DNS:*.wondersinmotion.com, DNS:*.ysnmail.com, DNS:*.z-nffcreview.ga, DNS:33kbcp.com, DNS:380992.com, DNS:arlingtonhighlands.com, DNS:avapelletier.tk, DNS:btchaber.com, DNS:centroybor.com, DNS:coinkolik.com, DNS:crowbase.org, DNS:distancebetweencities.net, DNS:distancy.com, DNS:dualarinsirri.com, DNS:evdennakliyateve.com, DNS:galvaniz.co, DNS:golgio.org, DNS:industrykhcnxb.ga, DNS:joshsreview-d.ga, DNS:meredithli.tk, DNS:mytownsquarelasvegas.com, DNS:nakliyatplatformu.com.tr, DNS:necessy.com, DNS:neyya.com, DNS:nlatestpdf.gq, DNS:osexandgodfilm.ga, DNS:paddockshops.com, DNS:paribu.io, DNS:paribu.xyz, DNS:postakoduara.com, DNS:sierragatehomes.ca, DNS:tickettapp2.com, DNS:ucnokta.org, DNS:whighbindersmovie.ml, DNS:wondersinmotion.com, DNS:ysnmail.com, DNS:z-nffcreview.ga
Yes, you should to avoid loops.
Cheers,
sahsanu
