Not showing verification
hi all,
I just installed certbot on my ubuntu server and configured the https certificate.
It seems to work, but when i check the certificate, it shows no information about the verification:
Verified by: Not specified
How should I fix that?
Here is my website: https://sentire.me
thanks!
The cause is non-obvious, but it’s caused by the mixed (insecure) content on your page.
Check out https://developers.google.com/web/fundamentals/security/prevent-mixed-content/what-is-mixed-content and https://www.whynopadlock.com/
Once you fix the mixed content on your page, the “verified by” will display “Let’s Encrypt” correctly.
Hi @buscon
use FireFox or Chrome, then Ctrl + Shift + I, that opens the console.
There you see a lot of content loaded via http, not https:
http://demo.qodeinteractive.com/bridge109/wp-content/uploads/2015/05/logo-sidearea.png
And bad: JavaScript or CSS, active content:
http://sentire.me/wp-content/plugins/LayerSlider/static/layerslider/skins/v6/skin.css
So check if you can use a wordpress plugin to change these links http -> https.
thank you both for your reply, i will work on moving the whole content to https and check it again.
I fixed the http content problem, now the verification is correct!
Thanks everyone and thanks to letsencrypt!
