To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
My web server is (include version): Rumpus server software 7.2.2
The operating system my web server runs on is (include version): Mac OS 10.14
My hosting provider, if applicable, is: Strato AG
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.14.0
I'm using a server software on my Mac with DynDNS from my hoster with the subdomain above and portforwarding in my router FritzBox 7490.
I have installed Brew and Certbot with the terminal. By completing the validation with the command above in the terminal to get the certificate I get the error message above.
In a Mac forum some users have told me that the issue is the appearing "/Login?" in the URL that is attached by the server software.
How can I complete the validation?
Regards
Thobie
You'll need to look into modifying your Rumpus webserver configuration to add an exception for serving /.well-known/acme-challenge/ without the redirect.
