Not able to create ssl on my hammart.in domain
My domain is: hammart.in
I ran this command:sudo certbot --nginx -d hammart.in
It produced this output:Requesting a certificate for hammart.in
Domain: hammart.in
Detail: 2a02:4780:11:1937:0:1648:93ad:8: Invalid response from http://hammart.in/.well-known/acme-challenge/2UWuuTfM86mtFTTzwcW5qofwWKwueOc20v-MU6ysDCk: 404
My web server is (include version):ubuntu 22
listen 80;
server_name hammart.in;
client_max_body_size 50M;
   location /.well-known/ {
   autoindex off;
    proxy_pass http://localhost:3001;
    proxy_http_version 1.1;
    proxy_set_header Connection 'upgrade';
    proxy_set_header Host $host;
    proxy_cache_bypass $http_upgrade;
the page is answered by Hostinger's Litespeed, not Nginx. does that ring a bell?
I don't have time to dig in it right now, but might be an IPv6 vs IPv4 issue here. Probably IPv6 being incorrect.
