I have tried to create LetsEncrypt certificate with one domain.
For checking deploy-hook i have tried to create certificate multiple times:( without knowing the limit. But now i am not able to create letsencrypt certificate.
Sorry for the same. But i need to complete my deliverable with in monday. Can you please help me in creating certificate one last time for my domain Pls:(
An unexpected error occurred:
There were too many requests of a given type :: Error creating new cert :: too many certificates already issued for exact set of domains: cogdev.asyncwq.cognizant.com
If you have deleted all files and folders, the only way to get a new certificate before Monday is adding a new domain to your cert.
You have reached the duplicate certificate limit (5 per 7 days) so you could create a new certificate covering your current domain cogdev.asyncwq.cognizant.com and for example a.cogdev.asyncwq.cognizant.com.
Note: Keep in mind that there is a limit of 20 certs per 7 days, so you should be careful and use staging Let’s Encrypt server instead of production if you are only testing the procedure.
if its a baremetal server , or hosted in local environment we can able to retrieve data using tools .
add preffix like cogdev1 temporarily and get certs. later you can get for the original name
If you can add an IP to a.cogdev.asyncwq.cognizant.com pointing to your web server yes, if not, you can add another domain you control, even a free one.
you must create A record for the new domain name . If you have creds of domain/ hosting panel, login to it and create A record . Or please inform system administrator . he will do it
it is virtual linux server.For Getting the domain name itself it took 2 months for me after long process followed. Now i cant create A record in it within short time:(
