No valid IP addresses found for shandrio.tk
Hi! I’m experiencing the following problem trying to request a new certificate using certbot. Running on Ubuntu 16.04 LTS:
# certbot-auto --apache -d shandrio.tk -d www.shandrio.tk
tls-sni-01 challenge for shandrio.tk
tls-sni-01 challenge for www.shandrio.tk
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Waiting for verification…
Failed authorization procedure. shandrio.tk (tls-sni-01): urn:acme:error:unknownHost :: The server could not resolve a domain name :: No valid IP addresses found for shandrio.tk
    Domain: shandrio.tk
    Type: unknownHost
    Detail: No valid IP addresses found for shandrio.tk
this is my 000-default.conf file contents in case it helps:
<VirtualHost *:80>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
ServerAdmin s****@gmail.com
ServerName shandrio.tk
ServerAlias www.shandrio.tk
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
</VirtualHost>
Any help would be greatly appreciated
Well, the error says it all: there's no IP address configured for shandrio.tk:
osiris@desktop ~ $ dig +norecurse @ns01.freenom.com shandrio.tk
; <<>> DiG 9.10.3-P4 <<>> +norecurse @ns01.freenom.com shandrio.tk
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 19114
;; flags: qr aa; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 2800
> ;; QUESTION SECTION:
;shandrio.tk. IN A
;; AUTHORITY SECTION:
shandrio.tk. 300 IN SOA ns01.freenom.com. soa.freenom.com. 1488564572 10800 3600 604800 3600
;; Query time: 26 msec
;; SERVER: 54.171.131.39#53(54.171.131.39)
;; WHEN: Fri Mar 03 22:18:30 CET 2017
;; MSG SIZE rcvd: 96
osiris@desktop ~ $
Compare this with www.shandrio.tk:
osiris@desktop ~ $ dig +norecurse @ns01.freenom.com www.shandrio.tk
; <<>> DiG 9.10.3-P4 <<>> +norecurse @ns01.freenom.com www.shandrio.tk
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 35734
;; flags: qr aa; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;www.shandrio.tk. IN A
;; ANSWER SECTION:
www.shandrio.tk. 14440 IN A 190.190.67.87
;; Query time: 25 msec
;; WHEN: Fri Mar 03 22:19:59 CET 2017
;; MSG SIZE rcvd: 60
osiris@desktop ~ $
Notice the first doesn't contain an answer.
So the type of action you need to follow is to go to your DNS provider and add an IP address for shandrio.tk, if possible.
Thanks! I don’t know exactly how to do that. I tried to add “*” name to the A DNS record but got an error. Adding nothing (empty name box) succeeded, but no response yet. Maybe I need to wait for it to propagate…
That was the right one, yes. A wildcard only works for subdomains, e.g., pointing *.example.com to an IP address will work for random-something.example.com, but not for example.com itself.
Anyhow, seems to work now:
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 65418
;shandrio.tk.			IN	A
;; ANSWER SECTION:
;; Query time: 31 msec
;; WHEN: Fri Mar 03 22:50:01 CET 2017
;; MSG SIZE  rcvd: 56
osiris@desktop ~ $
Let's Encrypt always asks the authorative nameserver, so it should not have to propagate.
Thanks again! I ran the script once more and now everything is working perfectly now. I have my site up with SSL!
