Shouldn't this be your servers' internal IP?:
Something more like: 192.168.x.x
Then your first task is to move the HTTP port of the router to some other number (not 80 & not 443).
If that is NOT possible... then "that is NOT possible".
Did a quick search on that error message and found this. How old is your firmware? Would this fix it?
https://www.geekzone.co.nz/forums.asp?forumid=81&topicid=245485
Partial quote from Feb 2019:
Since I have had the new NF18ACV router I am unable to successfully change the HTTP management port on the router. By default it is on port 80. However I want to run a webserver which requires NAT on 80.
Excellent find @MikeMcQ !
If that doesn't do the trick...
This workaround might be for a different router model but it is worth looking into:
https://www.geekrant.org/2020/04/26/setting-up-a-public-facing-webserver-behind-a-netcomm-nf18acv/
If everything fails, I'd speak with the ISP and see if they can provide an alternate router that can do what you need.
I tried updating the firmware yesterday and that broke my internet, so I had to downgrade it to be original version.
Thank you @rg305 for finding that. I managed to change the port.
The problem is that the web server is still unreachable when using the public IP address.
Now I can add port forwarding, but even that doesn't help.
It looks like the only option will be getting another router.
Anyways, thank you for all the help
I'm
If you were able to change the routers HTTP port (and disable the WAN side ports) how is it still saying?:
OR
Is it some new and different error msg now?
I think I know what's going on!
When you set the "HTTP service" to some other port, you moved that service from the router. [GOOD]
But...
When you went to create port forwarding you used "HTTP service" - which matches what the router is still using! [BAD]
You need to create a new additional service for HTTP80 and use that one for the port forwarding
There is no error message anymore, I can add the configuration now.
But if you try browsing to http://203.211.110.83/ it does not work.
Sorry I see that it is WAN:
But I would choose "Custom Service" instead.
Call it "AnythingUnique" and make sure it uses TCP port 80.
Same problem
grrrrrr....
[need more and must find a bigger
Have you rebooted the router since the HTTP was removed from it?
Hahaha
Rebooted the router. Still no luck.
I'll take a break.
I give up!
I'd ask the ISP for another model.
OR for their help.
No problem. Thank you for helping
Just a passing thought as I read the posts... Do you see DMZ anywhere in your router? You would have to tighten the firewall on the web server of course.
I've tried that too.
It seems to be bug with the firmware version, but if I upgrade the firmware the Internet stops working. I'll contact my ISP.
Thank you
