No valid IP addresses found for cyberrabbit.com
cyberrabbit.com
sudo certbot --apache
	1: cyberrabbit.com
	2: www.cyberrabbit.com
	http-01 challenge for cyberrabbit.com
	http-01 challenge for www.cyberrabbit.com
	Enabled Apache rewrite module
	Challenge failed for domain cyberrabbit.com
	Challenge failed for domain www.cyberrabbit.com
	   Domain: cyberrabbit.com
	   Type:   dns
	   Detail: No valid IP addresses found for cyberrabbit.com
	   Domain: www.cyberrabbit.com
	   Type:   dns
	   Detail: No valid IP addresses found for www.cyberrabbit.com
My DNS records:
	Type	Name					Value									TTL
	A		cyberrabbit.com			100.113.1.183								1 Hour
	A		www.cyberrabbit.com		100.113.1.183								1 Hour
	CNAME	_domainconnect			_domainconnect.gd.domaincontrol.com			1 Hour
	NS		@						ns01.domaincontrol.com						1 Hour
	NS		@						ns02.domaincontrol.com						1 Hour
	SOA	@						Primary nameserver: ns01.domaincontrol.com.	1 Hour
	CNAME	www					@										1 Hour
	A		@						100.113.1.183								1 Hour
Server version: Apache/2.4.41 (Ubuntu)
Server built: 2020-08-12T19:46:17
Ubuntu 20.04.2 LTS
N/A
I am running the website on a Raspberry Pi, model 4.
Local IP address: 192.168.1.2
URL: http://192.168.1.2
The website is accessible through port forwarding on my router.
Internet IP address: 100.113.1.183
URL: http://100.113.1.183
ssh ubuntu@192.168.1.2
no
I us godaddy.com only to manage my DNS records
This is a CGNAT address: Carrier-grade NAT - Wikipedia.
It means that your ISP does not give you a real IPv4 address. Instead, they have you share a pool of IP addresses with your fellow ISP customers.
Unfortunately this means you cannot effectively host a web server, because nobody outside your local network can connect to it.
If you want a certificate anyway, you might be able to get one using DNS validation. Since you use GoDaddy, you could use this method.
Hello @protteveel,
Based on your IP, I'm afraid you are using CGNAT so it is not possible to access your site from internet.
If you want a certificate you could use the dns challenge instead of http challenge.
Cheers,
sahsanu
Thanks for your reply, @sahsanu.
Can you explain how to use an http challenge instead, please?
I suppose you mean dns challenge.@_az already posted a link with info to use a dns plugin with GoDaddy but you should use acme.sh client instead of certbot.
Thank you both @_az and @sahsanu this is very helpful! :+1: because now I have a cert! :partying_face:
I was following the instructions How To Secure Apache with Let's Encrypt on Ubuntu 20.04.
But since my setup will not work with CGNAT and I have the cert now, can you maybe point me to the instructions on how to install it on Apache 2 for Ubuntu 20 LTS, please?
Within the same ISP... it maybe possible to remain unique and accessible.
However, LE is definitely outside that network and won't be able to validate it via HTTP from multiple global locations.
Do you mean that you have now obtained a certificate with acme.sh and would like to configure Apache to use it?
You'll have to configure Apache manually to do that, by creating an HTTPS virtualhost.
A good place to start is these two resources:
I think approximately you'll want to do something like:
acme.sh --install-cert -d cyberrabbit.com \
--fullchain-file /etc/apache2/cyberrabbit.crt  \
--key-file       /etc/apache2/cyberrabbit.key  \
--reloadcmd     "service apache2 reload"
then update your Apache configuration like so:
# intermediate configuration
SSLProtocol             all -SSLv3 -TLSv1 -TLSv1.1
SSLCipherSuite          ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
SSLHonorCipherOrder     off
SSLSessionTickets       off
SSLUseStapling On
SSLStaplingCache "shmcb:logs/ssl_stapling(32768)"
<VirtualHost *:443>
    ServerName cyberrabbit.com
    ServerAlias www.cyberrabbit.com
    # DocumentRoot /var/www/html/ (or wherever your site is)
    SSLEngine on
    SSLCertificateFile /etc/apache2/cyberrabbit.crt
    SSLCertificateKeyFile /etc/apache2/cyberrabbit.key
    Protocols h2 http/1.1
    # Then the rest of your website configuration goes here ...
</VirtualHost>
then reload Apache:
Untested instructions but they're the approximate outline of how to use your acme.sh-acquired certificate with Apache on Ubuntu.
Thanks, @_az; the website is now accessible through a secure connection: https://cyberrabit.com
curl -Iki https://cyberrabit.com/
curl: (6) Could not resolve host: cyberrabit.com
Screenshot_2021-02-03_12-35-43
Unfortunately, not for people outside of your own ISP, because of the CGNAT issue that was mentioned in the beginning of the thread. :frowning:
Thanks for letting me know, @schoen; much appreciated.
I am waiting for my ISP to get me a static IP address.
