The good news is that they are both pointing that alias to the same place ["/usr/share/phpmyadmin
So, I guess you can ignore the error:
OR remove one of them.
I still don't understand where you get that file from.
The server doesn't show that file:
There is normally a symbolic link from sites-enabled
into sites-available
. It can be created with a2ensite
@schoen, thanks for the breath of sanity.
Only the /sites-enabled/
files are included. Doh!
^ this file is not included in the config ^
I solved it this way
<VirtualHost *:80>
DocumentRoot /var/www/rgo.com.ve/public
<Directory /var/www/rgo.com.ve/public/>
AllowOverride All
Require all granted
RewriteEngine On
RewriteBase /var/www/rgo.com.ve/public
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php index.pl index.cgi index.html index.xhtml >
</IfModule>
</VirtualHost>
Thank you very much to all
