Today i run apt autoremove and now the following errors happened when i run certbot:
/usr/lib/python3/dist-packages/ndg/httpsclient/subj_alt_name.py:22: UserWarning: Error importing pyasn1, subjectAltName check for SSL peer verification will be disabled. Import error is: No module named 'pyasn1'
warnings.warn(import_error_msg)
/usr/lib/python3/dist-packages/ndg/httpsclient/ssl_peer_verification.py:25: UserWarning: SubjectAltName support is disabled - check pyasn1 package installation to enable
warnings.warn(SUBJ_ALT_NAME_SUPPORT_MSG)
Tried to reinstall pyasn1, but still theres an error.
Can you fill this form so we can help you better? (Since we have no clue what's your domain name or system version)
