www.dg1-test.jp
sudo certbot revoke --non-interactive --cert-path /tmp/certify_revoke_hBVaR2d3Vbo/live/www.dg1-test.jp/cert.pem --key-path /tmp/certify_revoke_hBVaR2d3Vbo/live/www.dg1-test.jp/privkey.pem --email sslcertificates@progmbh.com --preferred-challenges http --http-01-port=5002 --config-dir=/tmp/certify_revoke_hBVaR2d3Vbo --work-dir=/tmp/certify_revoke_hBVaR2d3Vbo --logs-dir=/tmp/certify_revoke_hBVaR2d3Vbo
Saving debug log to /tmp/certify_revoke_hBVaR2d3Vbo/letsencrypt.log
No match found for cert-path /tmp/certify_revoke_hBVaR2d3Vbo/live/www.dg1-test.jp/cert.pem!
My web server is (include version): cert was issued using the command:
certbot certonly --standalone ${DOMAINS} --non-interactive --agree-tos --email ${CERTBOT_AUTH_EMAIL} --preferred-challenges http --http-01-port=${CERTBOT_BOT_PORT} --config-dir=${TMP_FOLDER} --work-dir=${TMP_FOLDER} --logs-dir=${TMP_FOLDER}
Ubuntu 18.04
My hosting provider, if applicable, is: /
or certbot-auto --version
if you’re using Certbot):
certbot 0.28.0
Command’s exit code is 0, so it appears that something worked. When I check crt.sh it appears that the cert is revoked.
I would just like to know if “No match found for cert-path” is an error?
Thank you,
Valentin I.
