Nginx fails to start inside container
Nginx fails to start inside container because of missing SSL certificate on new docker-compose install.
PS: SSL certificates resides in the mentioned path.
Looking for solution.
Thanks
You might want to give us a little bit more information to work with.
I'm not sure how you've ended up in this "Help" section exactly, but if you selected it as a first choice for the section menu, you would have been presented with the following questionnaire:
Thanks for your attention.
Sorry, i can’t share my domain name. This is the error I,m seeing in the logs.
"cannot load certificate “/etc/letsencrypt/live/domainname/fullchain.pem”
You might not be able to get help here without sharing your domain name, but you should at least try answering all of the other questions in the form.
