My domain is:cvo.org.uk
I ran this command:certbot --authenticator webroot --installer apache -d cvo.org.uk
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer apache
http-01 challenge for cvo.org.uk
Input the webroot for cvo.org.uk: (Enter ‘c’ to cancel): c
Every requested domain must have a webroot when using the webroot plugin.
[root@s16329623 letsencrypt]# certbot --authenticator webroot --installer apache -d cvo.org.uk
Input the webroot for cvo.org.uk: (Enter ‘c’ to cancel): /var/www/vhosts/cvo.org.uk/httpdocs
Waiting for verification…
Deploying Certificate to VirtualHost /etc/httpd/conf/plesk.conf.d/vhosts/cvo.org.uk.conf
Redirecting vhost in /etc/httpd/conf/plesk.conf.d/vhosts/cvo.org.uk.conf to ssl vhost in /etc/httpd/conf/plesk.conf.d/vhosts/cvo.org.uk.conf
httpd not running, trying to start
(98)Address already in use: make_sock: could not bind to address [::]:443
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:443
no listening sockets available, shutting down
Unable to open logs
Unable to restart apache using [‘apachectl’, ‘graceful’]
Error while running apachectl restart.
Unable to open logs
Rolling back to previous server configuration…
Unable to open logs
Unable to open logs
Encountered exception during recovery:
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot_apache/_internal/configurator.py”, line 2419, in _reload
util.run_script(self.option(“restart_cmd”))
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot/util.py”, line 115, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apachectl graceful.
Unable to open logs
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot/_internal/client.py”, line 573, in enhance_config
self.installer.restart()
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot_apache/_internal/configurator.py”, line 2410, in restart
self._reload()
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot_apache/_internal/configurator.py”, line 2437, in _reload
raise errors.MisconfigurationError(error)
certbot.errors.MisconfigurationError: Error while running apachectl restart.
Unable to open logs
Unable to open logs
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot/_internal/error_handler.py”, line 125, in _call_registered
self.funcs-1
File “/opt/eff.org/certbot/venv/lib64/python3.6/site-packages/certbot/_internal/client.py”, line 630, in _rollback_and_restart
self._reload()
Unable to open logs
Unable to open logs
- An error occurred and we failed to restore your config and restart
your server. Please post to
https://community.letsencrypt.org/c/help with details about your
configuration and this error you received. - Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/cvo.org.uk/fullchain.pem
/etc/letsencrypt/live/cvo.org.uk/privkey.pem
Your cert will expire on 2020-10-05. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew”
[root@s16329623 letsencrypt]# service httpd status
httpd dead but pid file exists
[root@s16329623 letsencrypt]# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: (98)Address already in use: make_sock: could not bind to address [::]:443
Unable to open logs
[FAILED]
My web server is (include version):apache 2/nginx/plesk11.5
The operating system my web server runs on is (include version):centos 6
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):plesk 11.5
or certbot-auto --version
if you’re using Certbot):1.6.0
