My apologies for asking such a basic question, and maybe this is not possible, but I’m struggling getting LE setup for my server. Here’s my setup:
- I’m running Ubuntu 16.04 LTS with a typical LAMP setup
- I have a dynamic IP address through my ISP
- I use DuckDNS
I’ve installed let’s encrypt and have run the script to get the certificate:
% ./letsencrypt-auto --apache -d ****.duckdns.org
(where **** is my subdomain setup through DuckDNS)
When I run this, I get the following error:
Failed authorization procedure. ****.duckdns.org (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to (my IP address):443 for tls-sni-01 challenge
Domain: ****.duckdns.org
Type: connection
Detail: Failed to connect to (my IP address):443 for tls-sni-01
challengeTo fix these errors, please make sure that your domain name was
So, what am I doing wrong? Any tips would be most appreciated!
