My domain is:haslv.com
I ran this command: ```
sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challenges dns certonly
bitnami@ip-172-26-13-6:~$ sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challe
nges dns certonly
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you
requested and isn't close to expiry.
(ref: /etc/letsencrypt/renewal/haslv.com.conf)
What would you like to do?
1: Keep the existing certificate for now
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
My web server is (include version): Apache/2.4.41 (Unix)
The operating system my web server runs on is (include version):Ubuntu 16.04.6 LTS (GNU/Linux 4.4.0-1102-aws x86_64)
My hosting provider, if applicable, is: AWS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
The version of my client is (e.g. output of `certbot --version` or `certbot-auto --version` if you're using Certbot): not sure ?
