Need to Obtain Certs
Hello,
I have domain2.com IP A Host record set to my server, but when I attempt to obtain certificates for domain2.com and www.domain2.com it says it obtained them and then does not show that the siites have SSL certification.
Domain2.com shows Not Secured how to fix?
I've moved your thread to the "Help" topic. When you create a thread under this topic, the following questions are presented so that we can better help you. Would you please fill out the following?
Seventhseal.org shows Not Secure no SSL Certs in cPanel SSL/Status SSH says the domain has obtained a cert for www and .seventhseal.org
Seventhseal.org
I ran this command ./certbot-auto --apache --apache-server-root /etc/apache2 --apache-challenge-location /etc/apache2
Every cert installs no problem
My web server is CentOS 7
I can login to SSH
cPanel does not shows seventhseal.org and www.seventhseal.org has a cert
Hello,
My name is Kevin and I have a problem.
cPanel has already obtained a certificate for you… (Via autossl or let’s encrypt for cPanel)… But you seems to have some permission error since opening the domain throws a 403.
Thank you
Hello,
This problem is solved, I have found the solution.
