Need help with understanding why certificates cert00053-azurecdn.akamaized.net, cert00065-azurecdn.akamaized.net, cert00042-azurecdn.akamaized.net (37) is pending on Let's encrypt with error Let’s Encrypt: Order\u0027s status (\
Certificates cert00053-azurecdn.akamaized.net, cert00065-azurecdn.akamaized.net, cert00042-azurecdn.akamaized.net (37) is pending on Let’s encrypt with error Let’s Encrypt: Order\u0027s status (\
Could you please help us identify the root cause behind why these certificates are pending ? If there are any bad domains in the batch?
You should contact the vendor of your dashboard/panel.
That is not a particularly helpful message, and the error could be local to your machine, a problem with validation, or a problem with the request. The LetsEncrypt servers provide much detail in their responses - which is not showing on your software.
