Need help with tailscale and Certbot standalone for new cert
My domain is:www.hornet.technology
I ran this command:"sudo certbot delete --cert-name your_certificate_name"
then , "sudo certbot certonly --standalone --preferred-challenges http -d www.hornet.technology"
It produced this output: "Detail: : Fetching http://www.hornet.technology/.well-known/acme-challenge/DCL95cQcf9xb5lSNnRMIigPUZq2ich8xhMsaiLFJdNQ: Timeout during connect (likely firewall problem)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details."
My web server is (include version):go 1.20.8
The operating system my web server runs on is (include version):ubuntu 22.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.6.0
Hi @mrdp, and welcome to the LE community forum :slight_smile:
Using --standalone is difficult to troubleshoot.
You must ensure that HTTP can reach you system.
Also, why did you first delete your certificate?
First, you should not delete any active cert before requesting another one.
To debug the comms problem, do this
sudo certbot certonly --standalone --debug-challenges --preferred-challenges http -d www.hornet.technology
That will pause and show you a URL
Try accessing that URL from outside your local network. Even use a mobile phone with wifi off to use the carrier's network.
Or, while still paused post the URL here and we can check it
It seems the cert was recently expired :frowning:
But I agree with you, deleting a cert doesn't fix anything [and usually makes matters worse].
Yeah, to add background for benefit of other readers ...
There may be a service referring to those cert files which now don't exist. The service may now fail outright with missing files rather than just send an expired cert. Cert requests can fail for various reasons. It is even possible for Let's Encrypt to have a temporary outage.
i did not delete an active certificate it was expired and and i tried to renew the certificate but could't . so i deleted the old certificate .
" sudo certbot certonly --standalone --debug-challenges --preferred-challenges http -d www.hornet.technology
Requesting a certificate for www.hornet.technology
Challenges loaded. Press continue to submit to CA.
Pass "-v" for more info about challenges.
Press Enter to Continue
Domain: www.hornet.technology
Type: connection
Detail: 157.245.22.254: Fetching http://www.hornet.technology/.well-known/acme-challenge/FwQGRmmv63HKygQ3xtVPix38_cv_hCQ-QI8t1uqwPv0: Timeout during connect (likely firewall problem)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details. " got the same error again
We mean "active" in different ways. While expired if your web service still referred to those file locations it is still active. A client will see an expired cert but will still be able to make a TLS connection (usually HTTPS).
Sorry, I forgot to include the `-v' so please try below. But, when it says "Press continue to submit to CA." DO NOT press Enter to continue. Leave it paused and let us know the URL shown or try the URL from outside your network.
sudo certbot certonly --standalone -v --debug-challenges --preferred-challenges http -d www.hornet.technology
Expiration doesn't deactivate a cert.
It merely makes it "unsafe to use" - but it can still be used.
When you delete it, it can no longer be used; And that can create unintended problems [elsewhere].
± sudo certbot certonly --standalone -v --debug-challenges --preferred-challenges http -d www.hornet.technology
http-01 challenge for www.hornet.technology
The following URLs should be accessible from the internet and return the value
URL:
http://www.hornet.technology/.well-known/acme-challenge/y1PTWNViPqMriwcYvoyZmFwCDyQJRCDh6p9MSNux6aI
Expected value:
y1PTWNViPqMriwcYvoyZmFwCDyQJRCDh6p9MSNux6aI.Sc556KrbF2uAr8nBh3mzdbiHoWqg1aOoYmXGXmf7TuY
Good. With that left paused you can now try to reach that URL from outside your own network. I just tried it and timed out just like the Let's Encrypt error in your first post. So, we can reproduce the error.
So, it looks like a firewall may be blocking port 80. Or, your routing for that is not right.
Leave it paused like that while you try changes to your system to open that connection.
Just do a curl like below or even just paste the URL in a browser window. Just be sure to work from outside your own local network
curl -i -m10 http://www.hornet.technology/.well-known/acme-challenge/y1PTWNViPqMriwcYvoyZmFwCDyQJRCDh6p9MSNux6aI
Keep making changes until you don't get one of these :)
curl: (28) Connection timed out after 10000 milliseconds
If you have to restart Certbot it will give you a different URL so of course use the one it shows instead of the above
I get nothing:
curl http://www.hornet.technology/.well-known/acme-challenge/y1PTWNViPqMriwcYvoyZmFwCDyQJRCDh6p9MSNux6aI
○ curl -i -m10 http://www.hornet.technology/.well-known/acme-challenge/y1PTWNViPqMriwcYvoyZmFwCDyQJRCDh6p9MSNux6aI
HTTP/1.0 200 OK
Server: BaseHTTP/0.6 Python/3.8.10
Date: Tue, 03 Oct 2023 15:54:01 GMT
y1PTWNViPqMriwcYvoyZmFwCDyQJRCDh6p9MSNux6aI.Sc556KrbF2uAr8nBh3mzdbiHoWqg1aOoYmXGXmf7TuY%
From where?
Where from?
after running that on my server
Your server is not a good testing location.
You need to access it from the Internet.
[that is where the problem lies]
okay i'll try it from my local device
What shows?
ufw status
[or whatever command for the FW that is in use]
curl: (28) Failed to connect to www.hornet.technology port 80 after 129683 ms: Connection timed out
inactive
