I'm the author of the CertSage software that you're using.
Your password.txt file for CertSage will be located in the CertSage directory located in the parent directory of the directory where you put certsage.php, meaning that you just need to go up a folder from where you put certsage.php and you should see a folder named CertSage with a password.txt file in it. Your password is the entire contents of that file. Feel free to change the file's contents to whatever you want to use for your CertSage password.
When I visit your CertSage page it does not look like you've entered your domain names in the Domain and Subdomain Names box. You can find the instructions for CertSage here:
I also noticed that your website seems to be serving a new certificate from Sectigo:
