Need help with Certbot revoke in order to comply with tos
remote.random101.net
(I control *.random101.net I am just using remote.random101.net at this moment)
certbot revoke --cert-path revoke/5135cacd98930c8c1abe7beedfe39f8a3b91f30d49243c5734819290624b1f8b.pem
Unable to load: ,[('asn1 encoding routines', '', 'wrong tag'), ('asn1 encoding routines', '', 'nested asn1 error')]
nginx
certbot 2.9.0
just so the staff no my server was not comprized and neither was my dns server I just like playing around with the server for fun and that means i delete is a lot and generate a certifcate for the same domain very often
You do not have to revoke to comply with TOS just because you created a new cert
It is standard practice to get a new cert to replace a different one before it expires. A revoke is not required and even wasteful to do that every time.
Let's Encrypt has rate limits which might affect you if issuing new certs "very often". If you haven't yet be sure to see: Rate Limits - Let's Encrypt
Oh, and as for the error itself, what is in that .pem file? If a private key do not post it ! But, if it is a public leaf cert would you post it? Have you checked that it is a valid pem file using some SSL decoder? (openssl or otherwise)
This does not look like a cert issued with Certbot?
that a public key I know because i downloaded it on from crt.sh or one of their partners
I have absolutely no clue what you're doing or trying to do..
revoke an ssl certificate that is no longer is use. No key was comprimized if that was the case i would be emailing
There's simply no reason to do this.
No, you wouldn't email. There are other automated options in that case. See: Revoking Certificates - Let's Encrypt
The most likely reason for the error you see is a damaged pem file. I don't know why you'd need to download it from crt.sh. If it was one of yours I'd think you'd have a copy already.
In any case, you said it is a public leaf cert so please either post it or give a crt.sh link (or similar) so we can try to reproduce the bug you see.
You should also explain how you installed Certbot and what o/s you are using. You said "nginx" was your o/s but that isn't an o/s.
Just for info, revoking a cert is only necessary for key or account compromise and revoking a cert does not reset your rate limits, so if you hit a rate limit for duplicate certificates you still have to wait for that to reset regardless of whether you have revoked the cert or not.
