It produced this output: |Valid from|Wed, 22 May 2019 07:55:48 UTC|
|Valid until|Tue, 20 Aug 2019 07:55:48 UTC (expired 3 days, 9 hours ago) EXPIRED|
My web server is (include version): Siteground
My hosting provider, if applicable, is: Siteground
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): don’t know
I initiated a deletion about 10 hours ago - but still getting same error
It sounds like you did this within Siteground’s own interface and using their own tools. If so, you should most likely ask Siteground for help with that.
Thank you Schoen. I am and their support are normally first class - we are struggling. Hence my post. I have them looking at it again. The main domain looks fine - but the sub domain continues to be a problem.
Unfortunately, “deleting” a certificate is purely a hosting-environment-specific action; the certificate authority literally knows nothing about it and is not involved in it at all. That’s why the success or failure of this task will depend only on the details of the hosting environment and what it’s trying to do.
Thank you Juergen,
the linked record suggests that there is some residue of wildcard certificates still on Siteground.
I have forwarded to their support.
They are bogged down in the fact that the track.subdomain has a CNAME record to RedTrack - tracking software. However I think it is because the previous certificates were raised as wildcards is causing the issue.
Your help is really appreciated - the more information I get the better my chance of finding the resolution - so an education! I have bookmarked the URL of the analyzing tool - very useful!
Please refer to ticket 3233215 where our team has addressed the issue in more details. We have double-checked things on the server end and we can confirm that the expired SSL is not loaded from our server.
Our investigation revealed that the domain for which the expired Let’s Encrypt certificate is being detected points to an IP address that belongs to a different provider. We suggest you bring the issue to the technical team managing the remote server of this IP address. Alternatively, you can consider hosting the subdomain with SiteGround, and point it to us by changing existing CNAME for the sub domain to an A record which points to your account’s IP address, visible under cPanel.
For further assistance, please update ticket 3233215 after you hear back from the remote IP address remote host provider.
