I messed up the process and now I can't fix it. Probably it would be faster to restart the certification stage instead of correcting it. I re-run certbot several times and modified files in /etc/apache2/sites-available.
woa.ro, without https, works. With https it is not able to load.
webmail.woa.ro redirects to https and doesn't work either. Plain http worked at the beginning but I broke that, too.
Help would be greatly appreciated.
My domain is: woa.ro
I ran this command: many. Followed linuxbabe's tutorial and made some mistakes during the process.
It produced this output: Firefox says Unable to load.
My web server is (include version): Apache 2.4.52
The operating system my web server runs on is (include version): Raspberry OS (Debian 11-based) 64 bit
My hosting provider, if applicable, is: RCS & RDS S.A.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no. SSH only
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.12.0
"Can you undo/redo the process" - that was my question.
giving a more general answer, yes. I can start all over again but this process is more than 10 hours long and I'd really hate redoing all steps. The risk of making other mistakes is high.
So, I'd preferably avoid an infinite amount of work and would just fix one issue.
Do you have port 443 open? I see your site now and I can connect to http://woa.ro which redirects to https://woa.roa. That's fine but https fails to connect. These are ports I see:
53/tcp open domain
80/tcp open http
143/tcp closed imap
465/tcp open smtps
587/tcp open submission
1723/tcp closed pptp
Thanks a lot for the idea!
Didn't think it can be a problem inside the network. But the way my DNS is configured, no wonder, though.
Now I have some 403 Forbidden errors. Will work on that and I'll come back with the results.
