I have a domain name http://www.nexlesoft.com use open source Wordpress and web server running on Ubuntu’s digitalocean. I have read the documentation at https://www.digitalocean.com/community/tutorials/how-to-install-an-ssl-certificate-from-a-commercial-certificate-authority. I have a question that the certificate provided by Let’s Encrypt support www domain name? And if so, the implementation of the installation steps are similar to the domain does not have www? If not, do I have to buy Certificate Types Wildcard?
I did not find any documentation for the domain name www.
The option you are looking for is:
Multiple Domain: Known as a SAN or UC certificate, these can be used with…
The documentation you followed is not specific to LetsEncrypt and you may need to dig deeper to get the help you need.
In the meantime, try this read:
