Need assistance with pre-built VM
ocic.k12.ok.us
sudo certbot --apache
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
Apache
Unbutu 22
Yes
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.8.0
As subject says; an educational nonprofit was provided with a prebuilt Linux VM from the US Department of Education to collect survey data. I setup the VM on an internal host, and it is accessible and working---but has no SSL certificate.
I have full access to the server via webmin, and can edit or create what is necessary.
Thank you all.
this doesn't run on apache.
if you do not want to modify the VM, you can use whatever reverse proxy you're used to and have it handle tls termination.
Your DNS points to google services. You need the IP addresses to point to your host.
I should clarify; the server is survey.ocic.k12.ok.us
The DNS record for the server is not Google services
The server is survey.ocic.k12.ok.us
No, that domain is not :slight_smile:
But, the survey domain responds to HTTP requests from an nginx server. Not Apache.
If that is your reverse proxy to Apache VM the cert for it should be setup there. Otherwise, please explain more about your server config.
curl -i http://survey.ocic.k12.ok.us/.well-known/acme-challenge/Test404
HTTP/1.1 200 OK
Server: nginx/1.24.0
Thank you for the help.
Hmm.
(Apologies here, since I'm not a Linux admin by nature).
Webmin doesn't show nginx as one of the configured servers, but it clearly shows Apache. However, on a whim, I ran the installation instructions for nginx...and it worked. A certificate was installed for survey.ocic.k12.ok.us
However.
Step 8. I tested the command for automatic renewal, and it failed:
Failed to renew certificate survey.ocic.k12.ok.us with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/survey.ocic.k12.ok.us/fullchain.pem (failure)
Plus, the site still shows it is not secure
Also: receiving this error message now:
nginx restart failed:
nginx: [emerg] bind() to 0.0.0.0:443 failed (98: Address already in use)
nginx: [emerg] still could not bind()
Can you just talk us through your server configuration in your own words?
Describe the overview of where the nginx reverse proxy runs and where this Apache VM is (same machine, different, all on your premises, ...)
When you used certbot with --nginx plugin you told Certbot to setup nginx to handle port 443. But, the error is saying something is already using that port.
What does this show
sudo ss -pant | grep -i listen | grep -Ei ':80|:443|httpd|apache|nginx'
That's probably because you were supposed to follow "the webmin way" to TLS instead of installing certbot yourself.
