My domain is: puddle.zone and mirror puddlezone.ddns.net
I ran this command: sudo certbot certonly
1: Apache Web Server plugin - Beta (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 3
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c'
to cancel): puddle.zone puddlezone.ddns.net
requested (ref: /etc/letsencrypt/renewal/puddle.zone.conf)It contains these names: puddle.zone
You requested these names for the new certificate: puddle.zone,
puddlezone.ddns.net.Do you want to expand and replace this existing certificate with the new
certificate?(E)xpand/(C)ancel: E
http-01 challenge for puddle.zone
http-01 challenge for puddlezone.ddns.netSelect the webroot for puddle.zone:
1: Enter a new webroot
Press 1 [enter] to confirm the selection (press 'c' to cancel): 1
Input the webroot for puddle.zone: (Enter 'c' to cancel): /var/www/Select the webroot for puddlezone.ddns.net:
2: /var/wwwSelect the appropriate number [1-2] then [enter] (press 'c' to cancel): 2
Unable to clean up challenge directory /var/www/.well-known/acme-challenge
Failed authorization procedure. puddlezone.ddns.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.puddle.zone/.well-known/acme-challenge/EzBc-MAIMNg9kY0qY4i9OG50byWgZ8kR3DU3hmNePzQ: Error getting validation dataIMPORTANT NOTES:
Domain: puddlezone.ddns.net
Type: connection
Detail: Fetching
Error getting validation dataTo fix these errors, please make sure that your domain name was
My web server is (include version): Apache 2.4.27 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu Server 17.10 (Artful)
I've had puddle.zone set up with a cert, but due to timeout issues (likely associated with namecheap) I created a mirror dns record as puddlezone.ddns.net. Both addresses point to the same IP, and work, but the ddns one give an invalid cert (because only one domain has a cert at this time). Port 80 is blocked both by our firewall and by apache's firewall (it's supposed to be configured to force everything to https). I'm not using the apache validation method because it seems that's not compatable with ddns. For that, when I ran the command but chose apache instead of webroot, I got the following error
tls-sni-01 challenge for puddle.zone
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
