Nagios is not able to auto renew the certificate
When I am trying to auto renew the SSL certificate its showing me the below error.
Requesting a certificate for nagios1.tranzact.com
Domain: nagios1.tranzact.com
Type: connection
Detail: During secondary validation: 50.226.15.251: Fetching http://nagios1.tranzact.com/.well-known/acme-challenge/jSzj2jP7pXfMlfK27Np7vjKRL0da5MCJ93rX_xiod7Y: Timeout during connect (likely firewall problem)
Let's Encrypt check your domain from multiple geographic locations. A failure during "secondary" validation suggests you have a firewall or security product blocking http requests either from certain IP ranges or based on geographic location.
Yes the site is only accessible in US region.
what can be the solution for it?
Remove "defences" altogether or temporarily lift them for the challenges to complete.
It's preferable to at least allow all http requests to /.well-known/acme-challenge but that depends on the capabilities of your firewall.
You can also (in practice) block specific countries, assuming you have certain ones in mind, and still pass validation.
If you're firmly against http being open you would need to switch to DNS domain validation.
You may find this post helpful:
