My zone does not resolve
My domain is: estada.ch
I ran this command: certbot certonly --webroot -w /srv/letsencrypt_confirmation -d estada.ch -d www.estada.ch
http-01 challenge for estada.ch
http-01 challenge for www.estada.ch
Using the webroot path /srv/letsencrypt_confirmation for all unmatched domains.
Failed authorization procedure. estada.ch (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: query timed out looking up A for estada.ch, www.estada.ch (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: query timed out looking up A for www.estada.ch
   Domain: estada.ch
   Type:   connection
   Detail: DNS problem: query timed out looking up A for estada.ch
   Domain: www.estada.ch
   Type:   connection
   Detail: DNS problem: query timed out looking up A for www.estada.ch
Package: nginx
Version: 1.6.2-5+deb8u4
installed with apt
Debian 8 with all patches
ip-projects.de
yes and a month ago I was able to request a certificate for https://data.estada.ch
I suspect your verification service relies on googles public DNS resolver since they refuse to resolve to my zone and the error states the same.
If not, can you flush your DNS cache? Or do you have any hints?
Regards,
dns2utf8
Let’s Encrypt does not use Google Public DNS, but their resolvers do validate DNSSEC the same as Google Public DNS.
And your domain has DNSSEC issues:
http://dnsviz.net/d/estada.ch/dnssec/
To fix it, obtain the correct DS record from your DNS provider and update it with your domain name registrar. (Alternatively, you could remove the DS record on file with your registrar, but since your DNS provider does support DNSSEC it is better to just fix it.)
On top of that, DNSViz reports other warnings and errors, that some of the IP addresses seem to be down, and that the glue and authoritative records for ns1.estada.ch are not consistent.
While the DNSSEC thing was a critical issue, other problems won’t help reliability.
Thank you for the hints. I have been asking my registrar for a week now to update the glue records.
About the DS record, I extract it from knot with this command:
dig @localhost dnskey estada.ch +dnssec | grep 257
As far as I understand, this will return the KSK fingerprint. Correct?
I’m no DNSSEC expert but I don’t think that works. (I checked a domain I administer that has working DNSSEC and just renewed an LE certificate earlier this week and they do not match.)
According to the documentation for the knot DNS server, you would obtain the correct DS record with the following command:
keymgr zone key ds estada.ch +active
