My let's encrypt cerficate refused to renew using certbot
My domain is:fibblebox.com
It produced this output: All renewal attempts failed. The following certs could not be renewed:
/etc/letsencrypt/live/fibblebox.com/fullchain.pem (failure)
The operating system my web server runs on is (include version): ubuntu 20.04.4
Please share more of the Certbot output, preferably everything or even better the entire letsencrypt.log file.
Processing /etc/letsencrypt/renewal/fibblebox.com.conf
http-01 challenge for fibblebox.com
Challenge failed for domain fibblebox.com
Attempting to renew cert (fibblebox.com) from /etc/letsencrypt/renewal/fibblebox.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
This shows the Let's Encrypt server doing the http challenge on IPv6. When you have an AAAA record in your DNS it uses that instead of any A record. Your DNS looks like this but the IPv4 and IPv6 address return different results. This often means the AAAA record is wrong. It could also mean your nginx config is not configured for IPv6 listen properly. In either case, they should be returning the same result.
nslookup fibblebox.com
Address: 178.62.97.24
Address: 2a03:b0c0:1:d0::1172:1001
curl -I4 fibblebox.com
(uses IPv4)
Server: nginx/1.18.0 (Ubuntu)
Date: Wed, 22 Jun 2022 16:51:18 GMT
Content-Type: text/html
Content-Length: 178
curl -I6 fibblebox.com
(uses IPv6)
HTTP/1.1 200 OK
Date: Wed, 22 Jun 2022 16:51:23 GMT
Content-Length: 612
Last-Modified: Sat, 12 Mar 2022 11:27:58 GMT
ETag: "622c83be-264"
Accept-Ranges: bytes
i belive my nginx is well configured but do you have any solution to fix this
First, make sure your server IP's match your DNS. Run these commands on your server and check against the values I showed for DNS above (or your own DNS lookup):
curl -4 ifconfig.co
curl -6 ifconfig.co
If they do match, then please show the result of this and we'll take a look
sudo nginx -T
When I use IPv4 to your "home" page I see a page with data saying fibblebox. When I use IPv6 I only see a default IPv6 page. Something is wrong
The curl -4 ifconfig.co and curl -6 ifconfig.co the returned the same address to the one you sent above...
but the sudo nginx -T returned
IPv4 address for eth0: 178.62.97.24
IPv4 address for eth0: 10.16.0.5
IPv6 address for eth0: 2a03:b0c0:1:d0::1172:1001
IPv4 address for eth1: 10.106.0.2
it returned these addresses
that command should output your active nginx config. Can you paste that here? Please put three backticks before and after so it formats nice. Like this:
output of command
the output is much
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	# server_tokens off;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/conf.d/redirect.conf:
    server_name www.fibblebox.com;
    return 301 $scheme://fibblebox.com$request_uri;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
	listen 80 default_server;
	# SSL configuration
	root /var/www/html;
	server_name _;
		try_files $uri $uri/ =404;
	#location ~ \.php$ {
	#	include snippets/fastcgi-php.conf;
	#	# With php-fpm (or other unix sockets):
	#	fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
	#	# With php-cgi (or other tcp sockets):
	#	fastcgi_pass 127.0.0.1:9000;
	# concurs with nginx's one
	#location ~ /\.ht {
	#	deny all;
#server {
#	listen 80;
#	listen [::]:80;
#	server_name example.com;
#	root /var/www/example.com;
#	index index.html;
#	location / {
#		try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/fibblebox:
    server_name fibblebox.com www.fibblebox.com 178.62.97.24;
    location = /favicon.ico { access_log off; log_not_found off; }
    location /static/ {
        root /home/winter/fibblebox;
    location /media/ {
        include proxy_params;
        proxy_pass http://unix:/home/winter/fibblebox.sock;
    ssl_certificate /etc/letsencrypt/live/fibblebox.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/fibblebox.com/privkey.pem; # managed by Certbot
    if ($host = fibblebox.com) {
    } # managed by Certbot
    listen  80;
    server_name fibblebox.com 178.62.97.24;
# configuration file /etc/nginx/proxy_params:
proxy_set_header Host $http_host;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file. Contents are based on https://ssl-config.mozilla.org
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
Yes, it often is long. Can you update your post to use 3 backtick characters? It looks like you used 3 single quote chars. On US Keyboards it is just to the left of the number 1 key but I don't know about other keyboards.
Nevermind. I see you did that while I was writing. I will look at it now.
Great. Thanks.
Only your nginx default server block listens for IPv6. Because of this any request coming in on IPv6 goes to that default server and not your fibblebox server blocks.
You need to add IPv6 listen options on each of your servers. There are various ways to specify listen but you could do it like this (the first is IPv4, second is IPv6)
Port 80:
	listen 80;
	listen [::]:80;
Port 443 is:
	listen 443 ssl;
	listen [::]:443 ssl;
You need to add the 2 listen lines for port 80 in this server block:
And, there are two server blocks in /etc/nginx/sites-enabled/fibblebox
Each has an IPv4 listen (one for 443 and one for 80) so add the IPv6 listen after the existing listen lines.
Ok, I think that's it :slight_smile:
YES it has renewed thanks alot... you solved my 2 days stress in few replies.. i look up to (thank you)
