My ip is apparently blocked 86.111.12.92
That is more evidence that the routing problem is on your local network. I'm not sure how you can see it as anything else.
root@ucs:~# curl -i --connect-to ::172.253.115.139:443 https://dv.acme-v02.api.p ki.goog/directory
curl: (7) Failed to connect to 172.253.115.139 port 443: No route to host
root@ucs:~# curl https://api.buypass.com/acme/directory curl: (7) Failed to connect to api.buypass.com port 443: Connection timed out
It's probably Mikrotik. But I can't touch him right now.
Looks like you can't reach other Certificate Authorities either. Again, confirms not a Let's Encrypt issue.
Can you even reach this?
curl -4 https://www.cloudflare.com/cdn-cgi/trace
Thanks everyone, the problem was in Mikrotik. I restored the settings from Backup and everything worked.
Is this the correct report?
curl -v https://acme-v02.api.letsencrypt.org/directory
  • Trying 172.65.32.248...
  • TCP_NODELAY set
  • Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • successfully set certificate verify locations:
  • CAfile: none
    CApath: /etc/ssl/certs
  • TLSv1.3 (OUT), TLS handshake, Client hello (1):
  • TLSv1.3 (IN), TLS handshake, Server hello (2):
  • TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
  • TLSv1.3 (IN), TLS handshake, Certificate (11):
  • TLSv1.3 (IN), TLS handshake, CERT verify (15):
  • TLSv1.3 (IN), TLS handshake, Finished (20):
  • TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
  • TLSv1.3 (OUT), TLS handshake, Finished (20):
  • SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
  • ALPN, server accepted to use h2
  • Server certificate:
  • subject: CN=acme-v02.api.letsencrypt.org
  • start date: Mar 21 18:03:47 2025 GMT
  • expire date: Jun 19 18:03:46 2025 GMT
  • subjectAltName: host "acme-v02.api.letsencrypt.org" matched cert's "acme-v02.api.letsencrypt.org"
  • issuer: C=US; O=Let's Encrypt; CN=R11
  • SSL certificate verify ok.
  • Using HTTP2, server supports multi-use
  • Connection state changed (HTTP/2 confirmed)
  • Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
  • Using Stream ID: 1 (easy handle 0x5644d96aa750)
GET /directory HTTP/2
Host: acme-v02.api.letsencrypt.org
User-Agent: curl/7.64.0
Accept: /
Yes, that is correct. You can leave off the -v for such connectivity tests. That just adds verbose output for specific debugging purposes
