I have a weird problem. I set up my droplet and domain yesterday. I bought the domain on Hover and redirect it to Digital Ocean name servers. I’m using Nginx and Ubuntu 16.04. Everything worked fine but after some hours, I had this error when trying to access my website: allodocteuronline.com doesn't allow connection... ERR_CONNECTION_REFUSED
. I don’t always get that error but only sometimes. Another weird thing is sometimes, the Hover default web page is displayed as if the DNS is not propagated yet. I don’t see any error when analyzing my SSL with ssllabs.com. There is no error when I run sudo nginx -t
. But I have this error in /var/log/nginx/error.log:
2017/04/13 11:57:20 [crit] 29675#29675: *389 SSL_do_handshake() failed (SSL: error:14094085:SSL routines:ssl3_read_bytes:ccs received early) while SSL handshaking, client: 64.41.200.105, server: 0.0.0.0:443
/etc/nginx/sites-available/default
listen 80 default_server;
server_name allodocteuronline.com www.allodocteuronline.com;
return 301 https://$server_name$request_uri;
# SSL configuration
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
include snippets/ssl-allodocteuronline.com.conf;
include snippets/ssl-params.conf;
root /var/www/html;
index index.php index.html index.htm index.nginx-debian.html;
server_name allodocteuronline.com;
try_files $uri $uri/ =404;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
location ~ \.php$ {
include snippets/fastcgi-php.conf;
# # With php7.0-cgi alone:
# fastcgi_pass 127.0.0.1:9000;
# # With php7.0-fpm:
fastcgi_pass unix:/run/php/php7.0-fpm.sock;
# concurs with nginx's one
location ~ /\.ht {
deny all;
location ~ /.well-known {
allow all;
ssl_certificate /etc/letsencrypt/live/allodocteuronline.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/allodocteuronline.com/privkey.pem;
ssl-params.conf
# from https://cipherli.st/
# and https://raymii.org/s/tutorials/Strong_SSL_Security_On_nginx.html
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH";
ssl_ecdh_curve secp384r1;
ssl_session_cache shared:SSL:10m;
ssl_session_tickets off;
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.8.8 8.8.4.4 valid=300s;
resolver_timeout 5s;
# Disable preloading HSTS for now. You can use the commented out header line that includes
# the "preload" directive if you understand the implications.
#add_header Strict-Transport-Security "max-age=63072000; includeSubdomains; preload";
add_header Strict-Transport-Security "max-age=63072000; includeSubdomains";
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
