okay manual mode gets funnier every day.
it seems that every manually verified domain gets a different challenge and domains that are alreadyy verified also get a completely new challenge which is a really annyoing thing because I try to make a cert with 14 domains which all reside on my win-PC with XAMPP (some have different webroots compared to others, to isolate the secure stuff) so I have to run LE with manual from my raspi.
what made it worse, when I tried to copy a challenge somewhere in the middle I unconsiously used ctrl+C for copy on all normal system which canceled 6the whole procedure, it’s not LE’s fault but it’s annoying. is there some way to put a “do you really wanna cancel” question in there, or like many android apps have, you have to push back twice to exit.
so my Ideas for LE:
either:
use the same challenge for every domain requested under one cert and/or acc, so user A has a webroot challenge he can just pate everywhere needed but B still cannot certs A already got
and/or
if a domain is already verified for an acc, remember the challenge used and check whether or not it’s still there, so you dont need to put in a new one.
