mokumkraakt.nl
hotelmokum.org
2022-05-26 12:54:47,802:DEBUG:certbot._internal.main:Arguments: ['--config', '/etc/letsencrypt.ini', '--cert-name', 'npm-30', '--agree-tos', '--email', 'redacted@email.com', '--domains', '*.mokumkraakt.nl,mokumkraakt.nl', '--authenticator', 'dns-njalla', '--dns-njalla-credentials', '/etc/letsencrypt/credentials/credentials-30']
2022-05-26 12:56:39,374:DEBUG:certbot._internal.display.obj:Notifying user:
Certbot failed to authenticate some domains (authenticator: dns-njalla). The Certificate Authority reported these problems:
Domain: mokumkraakt.nl
Type: dns
Detail: DNS problem: SERVFAIL looking up TXT for _acme-challenge.mokumkraakt.nl - the domain's nameservers may be malfunctioning
Type: dns
Hint: The Certificate Authority failed to verify the DNS TXT records created by --dns-njalla. Ensure the above domains are hosted by this DNS provider, or try increasing --dns-njalla-propagation-seconds (currently 100 seconds).
openresty 1.19.9.1
debian 10
1984hosting
domain registered with njalla
Nginx-proxy-manager:
nginx-proxy-manager 2.9.16
or certbot-auto --version
if you're using Certbot):
1.27.0
Description:
Nginx Proxy Manager (NPM) runs in front of docker servers for both domains. When I request a wildcard cert for hotelmokum.org using the NPM web interface and the njalla authenticator it works fine, however for mokumkraakt it fails. Both domains are registered with njalla and have their own API keys.
