I would like to generate a multi domain SSL certificate with several different domains pointing to one of my AWS ELB.
However I’d like to have a script in place to be able to re-generate this multi domain ssl when a new domain will be pointing to my ELB so I can push the new multi domain certificate to it.
I’m not sure it is possible to generate a multi domain SSL certificate with http challenges that I would create automatically on my server (where the content is) and then verify automatically after the correct challenges have been created.
Since I will not be serving SSL on the server itself but on the ELB, I cannot use the webroot function of certbot.
Would you have a solution for this or any advices ?
Kind regards,
Mael
