Mixed content and https is not switched automatically
I can not understand the reason mixed contet. Help me please. My website: www.testkrol.tk
Installation was carried out according to the instructions, in addition to the installation nginh:
https://www.digitalocean.com/community/tutorials/how-to-secure-nginx-with-let-s-encrypt-on-ubuntu-14-04
I should nginx + apache.
P.s. when accessing the site does not automatically going to switch to https
test your site with https://www.whynopadlock.com - that will list all the files (css / images / themes) that you load using http in your code, not https ( hence it is “mixed” content, with some from http and otehrs from https.
You need to add a redirect if you want to force all traffic to use https. Are you using nginx ? or apache ?
Thanks for the link!
Nginx works as frontend, apache - backend.
Redirect set up according to the instructions above.
