jobst
February 15, 2022, 11:04pm
#1
I am running certbot (1.23.0) on all of my machines (CentOS7.X, snapd) with the following command once a night:
/bin/certbot renew --max-log-backups 25 --non-interactive --no-bootstrap --no-self-upgrade --renew-hook /etc/letsencrypt_renewhook
yet every single machine has 300 logfiles or more.
Since I have the problem on every machine I have I can only assume "max-log-backups" does not work.
Just to be sure: am I doing something wrong?
_az
February 15, 2022, 11:27pm
#2
The Certbot snap comes with its own systemd timer for automatic renewal. Setting up an additional cron job is not necessary.
These flags are related only to the deprecated certbot-auto
script, you can remove them.
jobst:
If you would like the Certbot renewal task to be affected by these flags, I suggest putting them in the global /etc/letsencrypt/cli.ini
file:
max-log-backups = 25
renew-hook = /etc/letsencrypt_renewhook
Osiris
February 16, 2022, 7:09am
#3
Isn't --renew-hook
written in the renewal configuration file?
_az
February 16, 2022, 7:15am
#4
Yes, one could alternatively configure deploy_hook
in the /etc/letsencrypt/renewal/*.conf
file for that individual certificate.
I try to avoid giving advice which involves modifying the .conf
files, at least until we have a better way to do it .
9peppe
#5
cli.ini
applies to every cert and it's supposed to be user editable.
The renewal configuration file is not supposed to be edited.
(I don't get setting the same renew hook for all certs, tho)
Osiris
February 16, 2022, 9:13am
#6
I meant: if you run renew
with a new option such as --renew-hook
, wouldn't that new option be saved into the renewal conf file by Certbot itself? If not, why not?
_az
February 16, 2022, 9:54am
#7
Yes, OP could also run a force renewal with a --deploy-hook
and avoid having to keep it in cli.ini
. That's the recommendation in the documentation .
jobst
February 16, 2022, 8:39pm
#8
I just read all replies - I will take up some of the suggestions made, thank you.
However, nobody commented on the fact that "--max-log-backups 25" isn't working for me - at all, as the title of the topic suggests this is my problem and still is.
rg305
February 16, 2022, 9:31pm
#9
It may have skipped that for several reasons.
Like:
because some of the other parameters were "obsolete" and conflicted/confused certbot
the expected log rotation service is not installed/supported by the underlying OS
I would try it again without the "obsolete" parameters.
MikeMcQ
February 16, 2022, 10:19pm
#10
Have you used --max-log-backups
from the beginning? Or did you add this after you noticed you had numerous log files?
I ask because it may not behave as you expect. I thought it would immediately trim my log history to the max but it does not. It rotates the latest X (25) logs going forward but any beyond that are orphaned.
Could this explain your situation?
rg305
February 16, 2022, 10:22pm
#11
Interesting...
@jobst
What shows
ls -ltr | tail -n 30
[on that directory]
jobst
February 17, 2022, 12:27am
#12
From the beginning.
At stages I actually have done a "rm -fr *" in the certbot logfile directory yet they still keep growing.
system
closed
March 19, 2022, 12:28am
#13
