My domain is: artprocess.org (and others in command)
I ran this command: sudo certbot certonly --cert-name artprocess.org --manual -d '.artprocess.org' -d artprocess.org -d '.justatest.com' -d justatest.com -d '.artprocess.com' -d artprocess.com -d '.artprocess.net' -d artprocess.net -d '.justatest.org' -d justatest.org -d '.justatest.ie' -d justatest.ie -d '*.alternativeart.org' -d alternativeart.org --email jp@justatest.com
My web server is (include version): tomcat 10.1.28
The operating system my web server runs on is (include version): Linux (Ubuntu 20.04.6 LTS)
My hosting provider, if applicable, is: Linode
or certbot-auto --version
if you're using Certbot): certbot 3.3.0
Manual renewal fails because of extra colon ":" in links e.g.:
Domain: alternativeart.org
Type: connection
Detail: 172.105.67.175: Fetching http://alternativeart.org/.well-known/acme-challenge/OJOSSQHWeLy_dfu9ubHlM8UCe_GSe60xAc5uJYImUf8: Connection refused
The setup instructed me to create the file: OJOSSQHWeLy_dfu9ubHlM8UCe_GSe60xAc5uJYImUf8
but the check at the end by the system looks for:
(that has an extra : at the end of the filename)
I've renewed my certificate this way for years now and this is the first time I've encountered this issue.
