Manual install fail through httpsforfree-gh on verifying ownership
#1
On step 4: in ‘Option 2 - file-based’ I’ve received this error.
Error: Domain challenge failed. Please start back at Step 1. {“type”:“http-01”,“status”:“invalid”,“error”:{“type”:“urn:acme:error:unauthorized”,“detail”:“Error parsing key authorization file: Invalid key authorization: malformed token”},“uri”:“https://acme-v01.api.letsencrypt.org/acme/challenge/rh9LUAnBU8CpjQRmV6T1KUP9xhbHuWwcnWDBZJ_Bn90/16047515",“token”:“Q7mxfMYX7oCZDXLS1QiQVyVFBhk7fgPM_ZXODuDLLDQ”,“keyAuthorization”:“Q7mxfMYX7oCZDXLS1QiQVyVFBhk7fgPM_ZXODuDLLDQ.zmG1Mo4BYCNmvWPyzHMZmMJGbuHOa6SNeAip8v6gPHk”,“validationRecord”:[{“url”:“http://tomashradcky.com/.well-known/acme-challenge/Q7mxfMYX7oCZDXLS1QiQVyVFBhk7fgPM_ZXODuDLLDQ”,“hostname”:“tomashradcky.com”,“port”:“80”,“addressesResolved”:[“74.208.87.168”],“addressUsed”:"74.208.87.168”}]}
I’ve read about and changed permissions on both the /.well-known folder and the /acme-challenge folder to 755 for each. I copied the text from each given url to be the file names in the /acme-challenge folder.
I wasn’t exactly sure what the ‘Serve this content:’ meant and thought that this needed to be text in the actual file itself, so I pasted it in the file and then uploaded the files to my server. After clicking “I’m now serving this file” I received the above error.
Any help here would be much appreciated as it seems I am close (hopefully) to getting the certs manually as I haven’t yet wrestled down letsencrypt-auto.
I’m running Yosemite and am hosted at 1and1.
Thanks much.
#2
You’ve created RTF files instead of plain text.
#3
Thank you, thank you. Just going to fast.
Will give it another shot today.
Much appreciated.
#4
Make sure both that the files’ contents are plain text and not RTF, and that they don’t end in a .rtf extension.
#5
Yesterday I went through a manual install again and got as far as part 2 of the fourth section when it failed. The 0.4.0 LE client release, along with a revamped local setup, came to the rescue and now I have my certs.
From here my next battle begins as I am on 1and1 and they do not provide cpanel for my package nor do they let you get to their version of ssl setup without purchasing a certificate.
I have yet, after a fews days of searching here and elsewhere, to find a way to properly install my certs in any ‘manual’ way. I have ssh and stfp access to my roots and have seen a .htaccess located in /log/.htacess.
I’m sending an e-mail out today to both the tech and sever support at 1and1 and we’ll go from there.
Thanks so much, schoen & cool110, for the help so far.
#6
And here are a couple of screen shots of my file structure.
#7
I received a reply from 1and1. See below.
My domain name is registered through Godaddy and I host on 1and1.
Now that I have my certificates is moving my hosting the only option I have if I want to use LetsEncrypt’s certs? Which I do as I don’t feel anyone should have to pay for something that’s become necessary in the world of google and is a good thing in general.
Thanks all, for the help and for doing all of this in general.
Dear Tomás Hradcky (Customer ID: --------),
Thank you for contacting us.
Please be informed that 1&1 SSL cannot be used with domain names that have modified DNS settings and/or a domain name registered/hosted with 1&1 using an external SSL. If you would like to apply an SSL certificate to a domain with modified name server or IP Address (A-Record) settings, please reset them to the default servers. This can be done from the 1&1 Control Panel. On the other hand, there is no option for domain names hosted with 1&1 to use an external SSL. However, if you wish, you can purchase your SSL Certificate here in 1&1. We are hoping for your consideration and understanding. We thank you for being a long time 1&1 customer.
If you have any further questions, do not hesitate to contact us.
Sincerely,
Renan Joshua Jamola
Technical Support
1&1 Internet Inc.
1and1 response to query to allow LetsEncrypt Certs
