Manual DNS Challenge fails with NXDOMAIN on TXT
Can you please provide me a certificate or help me to get it?
What does this show?
sudo certbot certificates
PFA snap
Please run and share the output
curl -4 ifconfig.co
curl -6 ifconfig.co
and/or
curl -4 ifconfig.io
curl -6 ifconfig.io
Clearly you have in the past obtained and served this certificate
What is my IP address? — ifconfig.co
https://ifconfig.co/
From the console screen you show here Manual DNS Challenge fails with NXDOMAIN on TXT - #23 by 3lineofcode
curl -4 ifconfig.co
curl -6 ifconfig.co
and/or
curl -4 ifconfig.io
curl -6 ifconfig.io
Also presently only Port 80 is Open
https://tools.letsdebug.net/cert-search?m=domain&q=3lineofcode.in&d=168
Rate Limit Current Status Domain
50 Certificates per Registered Domain per week OK (7 / 50 this week.) 3lineofcode.in
5 Duplicate Certificates per week Limit exceeded. Next issuable at 16 Apr 2023 16:36:10 UTC 3lineofcode.in
Summary generated at letsdebug-toolkit .
yes my website is live on port 80, i want SSL cert i don't know what r you talking about.please help me out how to get SSL
Well given the Rate Limits are exceeded and you have plenty of time to wait be for getting a Let's Encrypt issued certificate.
Please start by reading Getting Started - Let's Encrypt
And consider testing and debugging are best done using the Staging Environment
And to assist with debugging there is a great place to start is Let's Debug.
Also there are other Free ACME Certificate Authorities to select from as well
Can you please help me to share assigned certs?
Yes, here it is:
Click on one and use
from here
Of course you will need your associated PRIVATE KEY to make use of the Certificate; I am assuming you have the PRIVATE KEY(s).
Unfortunately not, I don't even know where to use and how to use.
BTW thanks for your prompt support.
Appreciate if you help me with further steps.
Regards,
Mohammed Faruk
Not showing certificates, Now after how many days can I get back issue?
Regards,
Mohammed Faruk
That error tells you when you will be able to get a production certificate again.
Please take account of the documentation and testing resources that people in this thread have shared with you so that you can learn more about the process and also check whether your site (as seen by the rest of the Internet) has the setup that you expect it to.
Dear Team,
Thank you for letting me know about the error you received.
The error message indicates that we need to wait until 2023-04-14T00:43:53Z before we can try to obtain a new production certificate again.
Also, just for your information, the timestamp 2023-04-14T00:43:53Z that you mentioned in your message corresponds to 2023-04-14 06:13:53 IST (Indian Standard Time) in India. This is because Indian Standard Time is 5 hours and 30 minutes ahead of UTC. I hope this helps.
In the meantime, I will review the documentation and testing resources shared by others in this thread to ensure that our site is set up correctly. Thank you for your help and patience.
Once again thank you so much for your continuous and prompt support❣️.
Regards,
Mohammed Faruk
3lineofcode.in
