Manual certification has stopped working
My domain is: https://sasc.beberibe.ce.gov.br/
I ran this command: sudo certbot certonly --webroot -w /var/www/letsencrypt -d sasc.beberibe.ce.gov.br
Requesting a certificate for sasc.beberibe.ce.gov.br
http-01 challenge for sasc.beberibe.ce.gov.br
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Challenge failed for domain sasc.beberibe.ce.gov.br
    Domain: sasc.beberibe.ce.gov.br
    Type: connection
    Detail: 189.126.73.242: Fetching
    http://sasc.beberibe.ce.gov.br/.well-known/acme-challenge/FKRhiNtqDV3Oywy4OwFRsHuEu30iP0ANlAxeB9Td-ec:
My web server is (include version): nginx version: nginx/1.18.0
The operating system my web server runs on is (include version): Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
I have been using this certification method for a while, however, after I implemented automatic certification, this method stopped working correctly, now I need to return the systems with their certifications.
There is no webserver listening on port 443 (I'm getting a connection refused) and port 80 seems to timeout entirely, probably a firewall thing as also mentioned by the error message already.
Please make sure your website is up and running, including port 80 (a redirect to HTTPS is fine) and try again.
Atualmente eu estou servindo usando Nginx configurado na porta 80. Quando eu uso do comando de debug, que para a aplicação ao gerar o arquivo, o arquivo de confirmação é gerado corretamente, tenho acesso a ele pelo navegador externo ao servidor e acesso também via "curl", mas o let's encritp não encontra esse aquivo. Eu já vi o firewall e está tudo ok, era possível o firewall bloquear do o acesso ao let's encript.
I am currently serving using Nginx configured on port 80. When I use the debug command, which stops the application when generating the file, the confirmation file is generated correctly, I have access to it through the browser external to the server and also access via "curl", but let's encrypt does not find this file. I have already checked the firewall and everything is ok, it was possible that the firewall blocked access to let's encrypt.
Have you also tried from outside your own network? I.e., using your phone without WiFi? Or VPN? Because your website is still NOT reachable from the global internet.
See e.g. Let's Debug that also tries to connect itself.
Then there must be something else blocking global access to your site. Perhaps at the ISP level, perhaps a missing NAT portmap, I don't know.
Please make sure Let's Debug or other worldwide connection testing sites can connect to your site before trying again with Let's Encrypt.
Based on the information you gave me, I did some tests here. I used the command “sudo certbot certonly --webroot -w /var/www/letsencrypt -d sasc.beberibe.ce.gov.br -debug-challenges”, when the command runs the file is created correctly, in another terminal I list the existing files in the directory, and the file is there correctly created. In the same terminal that I checked the existence of the file I use the command “curl -i http://sasc.beberibe.ce.gov.br/.well-known/acme-challenge/[arquivo]“ and I get the return:
“HTTP/1.1 200 OK
Server: nginx/1.18.0
Date: Wed, 09 Apr 2025 17:20:56 GMT
Content-Type: text/plain
Content-Length: 87
Last-Modified: Wed, 09 Apr 2025 17:08:23 GMT
ETag: "67f6a987-57"
This indicates that the file is being served correctly on the server. We should note that this test was performed on the server in question. When we requested the files via the browser on a machine that is on the same network as the server, we received a successful response. The problem occurs when we request the files on an external network. In my case, I used the telephone company's network. Another test was performed by running the command “tracert sasc.beberibe.ce.gov.br” on the machine that was using a network external to the server. We observed a delay in displaying the routes and hops with errors, possibly due to timeouts. Contact your internet provider. They want to know who is requesting the files, which in this case is Let's Encrypt. I believe they want to identify the requester, which could be the IP address.
Let's Encrypt does not provide a list of IP addresses from where the challenges are being performed, as those IP addresses can change at any notice.
Please note that it isn't just Let's Encrypt that can't access your server.
You said your own tests cannot reach your domain when using the public internet.
You can use that test when working with your network experts to identify the problem.
Also see a test site like this: Check website performance and response : Check host - online website monitoring
That is a test to your "home" page using HTTP (port 80). It has nothing to do with Let's Encrypt
