I am working on setting up nextcloudpi on a Raspberry Pi 4. I was having issues with it and ended up wiping the SD card but I never thought to backup the certificate. Now I am getting errors from letsencrypt and can’t proceed.
My domain is: allamancloud.ftp.sh
I ran this command: while running the setup wizard for nextcloudpi, it tries to setup letsencrypt but errors out
acme.messages.Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: allamancloud.ftp.sh: see https://letsencrypt.org/docs/rate-limits/
2019-08-06 10:52:45,286:ERROR:certbot.log:An unexpected error occurred:
2019-08-06 10:52:45,287:ERROR:certbot.log:There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: allamancloud.ftp.sh: see https://letsencrypt.org/docs/rate-limits/
My web server is (include version): Raspbery Pi 4
The operating system my web server runs on is (include version): Raspbian buster
My hosting provider, if applicable, is: n/a
If you’ve hit a rate limit, we don’t have a way to temporarily reset it. You’ll need to wait until the rate limit expires after a week. We use a sliding window, so if you issued 25 certificates on Monday and 25 more certificates on Friday, you’ll be able to issue again starting Monday.
Thank you for the reply, I did not know those certs existed… I had trouble getting nextcloud installed and I guess it did that work in the background. Those, too, would have been wiped when I wiped the SD card, however.
