I followed everything exactly as is, except I already have a domain with cloudflare so I did not need to transfer one from GoDaddy like he did. However, I keep getting this error
"DNS problem: NXDOMAIN looking up TXT for _acme-challenge.(mydomain)- check that a DNS record exists for this domain.
Hint: The Certificate Authority failed to verify the DNS TXT records created by --dns-cloudflare. Ensure the above domains are hosted by this DNS provider, or try increasing --dns-cloudflare-propagation-seconds (currently 10 seconds)."
From my research into it, it looks like maybe I needed to configure the DNS records? So I added the following
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
