Exactly as it says. I’m pretty sure it’s not working, but not having the output is frustrating me. Right when the program seems to finish doing a thing, it just quits and closes the console window, I can’t read what happened.
My domain is: Dakkadefender.com
letsencrypt.exe
It closes the window every time <—The problem
XAMPP // Apache
Server version: Apache/2.4.28 (Win32)
Windows 10 Home
yes (well, if you want to call cmd.exe a root shell, sure)
nope
As @ahaw021 pointed, letsencrypt.exe is a clilent developed by a third party so you could get more help on their github site.
Anyway, I suppose letsencrypt.exe is opening a new command window because the command window where you are executing it has no admin privileges so the program needs to open a new one, do something and closes it immediately. To avoid this:
1.- Click on Windows Start button. 2.- Type cmd 3.- In the results, right click on Command Prompt and click on Run as administrator
4.- From this command prompt, navigate to the dir where letsencrypt.exe is installed and execute the command again.
