I have a DC/OS (V1.9.0) running on Azure. Marathon V 1.4.2.
The Letencrypt DC/OS has been renewing the certificates in the past without issue until now it is not renewing and the certificates will be expired in 5 days.
My domain is: estimating.fletcherinnovation.com
dcos marathon app add letsencrypt-dcos.json
Then I can see that deployment was taken place, and it tries to regenerate and renew the certificates.
But then it fails with the error message below:
NOTES:
- If you lose your account credentials, you can recover through
e-mails sent to digital.developer@fbu.com.
Domain: estimating.fletcherinnovation.com
Detail: Invalid response from
http://estimating.fletcherinnovation.com/.well-known/acme-challenge/7-uu0vj7wlTcnwkd52SAs9K_-CsDoy6Lle9Whkf33eM
[52.187.235.74]: 503
Domain: fbwebprod001.fletcherinnovation.com
http://fbwebprod001.fletcherinnovation.com/.well-known/acme-challenge/UdiK8HMk0avn953Awy6jdi6aY_VKcmwFDK4Xi80gwfc
Domain: api.parse.fletcherinnovation.com
http://api.parse.fletcherinnovation.com/.well-known/acme-challenge/CegdIygwD16fZi5CiJM3bArmEV7UBamiEbVT9NXu8zY
Domain: jenkins002.fletcherinnovation.com
http://jenkins002.fletcherinnovation.com/.well-known/acme-challenge/rJndFIsA9nydl61bInXMxE3X68erwHj6u9LH47aTtF4
Domain: api.roofing.fletcherinnovation.com
http://api.roofing.fletcherinnovation.com/.well-known/acme-challenge/1Obkc-FMLR_uo8dXMPcWYAMLK77AiyaWq6NvgeVg9Rw
My hosting provider, if applicable, is: Azure
Yes, I can login to root.
I can use DCOS UI, or I can also use shell.
or certbot-auto --version
if you’re using Certbot): I am not sure about this, as we used the letsencrypt dcos to do the work.
Please help out. and I might be missed some information here. so please if you think I didn’t add enough information to this.
Cheers
