mogul.network
torrent.mogul.network for my torrents
cloud.mogul.network for my cloud, etc.
sudo sudo letsencrypt certonly -a webroot --webroot-path=/var/www -d mogul.network -d i.mogul.network -d hir.i.mogul.network -d cloud.mogul.network -d torrent.mogul.network -d netdata.mogul.network -d archive.mogul.network -d mail.mogul.network
Failed authorization procedure. netdata.mogul.network (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://netdata.mogul.network/.well-known/acme-challenge/FJGOnOh9Fe23eVU3PlDUtBOSxg22eW-YvoHuHKbTBBc: "<html>
<head><title>401 Authorization Required</title></head>
<body bgcolor="white">
<center><h1>401 Authorization Required</", torrent.mogul.network (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://torrent.mogul.network/.well-known/acme-challenge/-X_yYF4LjQ2Iz7TxUlEoVTxXzP0PDTkl-OMZZgvq_4M [5.158.135.200]: 401
Domain: netdata.mogul.network
Detail: Invalid response from http://netdata.mogul.network/.well-
"<html>
Domain: torrent.mogul.network
Detail: Invalid response from http://torrent.mogul.network/.well-
Ubuntu 16.04.1 LTS
nginx version: nginx/1.10.0 (Ubuntu)
Its hosted on my own server.
no
Additional configs
Because it might help to narrow down the problem I also add the “sites-enabled” config files for transmission and netdata
transmission
listen 80;
server_name torrent.mogul.network;
return 301 https://$server_name$request_uri;
listen 443 ssl http2;
include snippets/ssl-mogul.network.conf;
include snippets/ssl-params.conf;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
proxy_read_timeout 300;
proxy_pass_header X-Transmission-Session-Id;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_pass http://127.0.0.1:9091/transmission/web/;
location /rpc {
proxy_pass http://127.0.0.1:9091/transmission/rpc;
location /upload {
proxy_pass http://127.0.0.1:9091/transmission/upload;
netdata
upstream backend {
# the netdata server
server 127.0.0.1:19999;
keepalive 64;
listen 80;
server_name netdata.mogul.network;
auth_basic "Protected";
auth_basic_user_file passwords;
proxy_pass http://backend;
proxy_http_version 1.1;
proxy_pass_request_headers on;
proxy_set_header Connection "keep-alive";
proxy_store off;
Both transmission and netdata ask for credentials (login) to access. I don’t know how to create the certificates while having the credentials still in place.
All other sub domains seem to work well. E.g cloud.mogul.network for nextcloud. I tried to find a solution with google and also found a guy using Nginx, transmission & letsencrypt. But I don’t understand how he/she could create (and renew) the certificates.
I hope someone give me the right hint. I might be just blind.
Thank you very much.
Hir i Mogul
