I ran this command (as a shell script):
# Renew Let's Encrypt SSL cert
cd /opt/letsencrypt
./letsencrypt-auto certonly --cert-name media.temojo.org -c /etc/letsencrypt/cli.ini -w /var/www/LEwebroot/ -d media.teamojo.org
if [ $? -ne 0 ]
then
ERRORLOG=`tail /var/log/letsencrypt/letsencrypt.log`
echo -e "The Lets Encrypt Cert has not been renewed! \n \n" $ERRORLOG | mail -s "Lets Encrypt Cert Alert -" email@example.com
else
service apache2 reload
echo -e "Success! The Lets Encrypt Cert has been renewed!" | mail -s "Lets Encrypt Cert Alert +" email@example.com
fi
exit 0
(with this cli.ini):
# This is an example of the kind of things you can do in a configuration file.
# All flags used by the client can be configured here. Run "Let's Encrypt" with
# "--help" to learn more about the available options.
# Use a 4096 bit RSA key instead of 2048
rsa-key-size = 4096
# Always use the staging/testing server
# server = https://acme-staging.api.letsencrypt.org/directory
# Uncomment and update to register with the specified e-mail address
email = email@example.com
# Uncomment to use a text interface instead of ncurses
text = True
agree-tos = True
authenticator = webroot
Here is the alias config for /var/www/LEwebroot:
Alias /.well-known /var/www/LEwebroot/.well-known
<Directory /var/www/LEwebroot/.well-known>
Options FollowSymlinks
AllowOverride All
Order allow,deny
Require all granted
</Directory>
http-01 challenge for media.teamojo.org
Using the webroot path /var/www/LEwebroot for all unmatched domains.
Failed authorization procedure. media.teamojo.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to media.teamojo.org.well-known
Domain: media.teamojo.org
Type: connection
Detail: Could not connect to media.teamojo.org.well-known
Server version: Apache/2.4.18 (Ubuntu)
Ubuntu 16.04.02
Note: I find it odd that the error is that no connection could be made to example.com.well-known rather than example.com/.well-known
I can connect to the domain url normally.
