Letsencrypt-auto script stuck
My domain is:dizipi.com
Currently i’m using CloudFlare SSL but i want to disable cloudflare so i decided to use letsencrypt.
My server is details is
Plesk v12.5.30_build1205150826.19 os_CentOS 7
CentOS Linux 7.2.1511 (Core)
I ran this command ./letsencrypt-auto certonly --standalone -d dizipi.com -d www.dizipi.com --debug
And it stuck here
Bootstrapping dependencies for RedHat-based OSes…
yum is /usr/bin/yum
What is problem ? Thanks
Is your system up-to-date ? if you do a
yum update
what response do you get ?
My problem solved. The reason is server can’t connect to autoinstall.plesk.com plesk repository and it stuck. After I fix connection issue my problem fixed.
