My domain is: localhost–>so no domain
I ran this command: sudo certbot certonly --standalone -d temp.humhub.dev
Let’s Encrypt won’t just hand out a certificate for a domain you don’t control. As such, the only way these instructions would work for you is if you had your own domain, and a publicly accessible webserver to which that domain points.
In cases like these, where you’re just doing something locally, it might be better to generate a certificate using a tool like mkcert.
