Result of “ sudo ls -alR /etc/letsencrypt/
Last login: Mon Aug 19 09:03:29 CEST 2019 on pts/1
/etc/letsencrypt/:
total 36
drwxr-xr-x. 9 root root 4096 Aug 19 09:03 .
drwxr-xr-x. 95 root root 8192 Aug 14 17:11 …
drwx------. 4 root root 84 Aug 14 18:54 accounts
drwx------. 4 root root 47 Aug 16 09:36 archive
drwxr-xr-x. 2 root root 4096 Aug 19 09:03 csr
-rw-r–r--. 1 root root 3901 May 21 11:24 esmc.rta.lv.jks
drwx------. 2 root root 4096 Aug 19 09:03 keys
drwx------. 3 root root 37 May 21 11:17 live
-rw-r–r--. 1 root root 1591 May 20 12:59 options-ssl-apache.conf
drwxr-xr-x. 2 root root 57 May 22 07:05 renewal
drwxr-xr-x. 5 root root 40 May 20 12:56 renewal-hooks
-rw-r–r--. 1 root root 64 May 20 12:59 .updated-options-ssl-apache-conf-digest.txt
/etc/letsencrypt/accounts:
total 4
drwx------. 4 root root 84 Aug 14 18:54 .
drwxr-xr-x. 9 root root 4096 Aug 19 09:03 …
drwx------. 3 root root 22 Aug 14 18:54 acme-staging-v02.api.letsencrypt.org
drwx------. 3 root root 22 May 20 12:59 acme-v02.api.letsencrypt.org
/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org:
total 0
drwx------. 3 root root 22 Aug 14 18:54 .
drwx------. 4 root root 84 Aug 14 18:54 …
drwx------. 3 root root 45 Aug 14 18:54 directory
/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org/directory:
total 0
drwx------. 3 root root 45 Aug 14 18:54 .
drwx------. 3 root root 22 Aug 14 18:54 …
drwx------. 2 root root 61 Aug 14 18:54 1111c7f0bbed2c790afdbfeddb9b5fc2
/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org/directory/1111c7f0bbed2c790afdbfeddb9b5fc2:
total 12
drwx------. 2 root root 61 Aug 14 18:54 .
drwx------. 3 root root 45 Aug 14 18:54 …
-rw-r–r--. 1 root root 74 Aug 14 18:54 meta.json
-r--------. 1 root root 1632 Aug 14 18:54 private_key.json
-rw-r–r--. 1 root root 86 Aug 14 18:54 regr.json
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org:
total 0
drwx------. 3 root root 22 May 20 12:59 .
drwx------. 3 root root 45 May 20 13:02 directory
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory:
total 0
drwx------. 3 root root 45 May 20 13:02 .
drwx------. 3 root root 22 May 20 12:59 …
drwx------. 2 root root 61 May 20 13:02 6767caf4ec753d20c3dd39423d3539b3
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory/6767caf4ec753d20c3dd39423d3539b3:
total 12
drwx------. 2 root root 61 May 20 13:02 .
drwx------. 3 root root 45 May 20 13:02 …
-rw-r–r--. 1 root root 74 May 20 13:02 meta.json
-r--------. 1 root root 1632 May 20 13:02 private_key.json
-rw-r–r--. 1 root root 78 May 20 13:02 regr.json
/etc/letsencrypt/archive:
total 8
drwx------. 4 root root 47 Aug 16 09:36 .
drwxr-xr-x. 2 root root 4096 May 22 07:05 esmc.rta.lv
drwxr-xr-x. 2 root root 79 May 21 11:17 esmc.rta.lv-0001
/etc/letsencrypt/archive/esmc.rta.lv:
total 36
drwxr-xr-x. 2 root root 4096 May 22 07:05 .
drwx------. 4 root root 47 Aug 16 09:36 …
-rw-r–r--. 1 root root 1899 May 21 08:08 cert1.pem
-rw-r–r--. 1 root root 1899 May 22 07:05 cert2.pem
-rw-r–r--. 1 root root 1647 May 21 08:08 chain1.pem
-rw-r–r--. 1 root root 1647 May 22 07:05 chain2.pem
-rw-r–r--. 1 root root 3546 May 21 08:08 fullchain1.pem
-rw-r–r--. 1 root root 3546 May 22 07:05 fullchain2.pem
-rw-------. 1 root root 1708 May 21 08:08 privkey1.pem
-rw-------. 1 root root 1708 May 22 07:05 privkey2.pem
/etc/letsencrypt/archive/esmc.rta.lv-0001:
total 16
drwxr-xr-x. 2 root root 79 May 21 11:17 .
-rw-r–r--. 1 root root 1903 May 21 11:17 cert1.pem
-rw-r–r--. 1 root root 1647 May 21 11:17 chain1.pem
-rw-r–r--. 1 root root 3550 May 21 11:17 fullchain1.pem
-rw-------. 1 root root 1704 May 21 11:17 privkey1.pem
/etc/letsencrypt/csr:
total 228
drwxr-xr-x. 2 root root 4096 Aug 19 09:03 .
-rw-r–r--. 1 root root 920 May 20 13:02 0000_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 13:24 0001_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 13:25 0002_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 13:28 0003_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 13:40 0004_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 13:45 0005_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 14:18 0006_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 14:20 0007_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 14:22 0008_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 14:28 0009_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 15:33 0010_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 18:50 0011_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 18:52 0012_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 18:54 0013_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 19:01 0014_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 19:46 0015_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 20 20:18 0016_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 21 08:08 0017_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 21 11:17 0018_csr-certbot.pem
-rw-r–r--. 1 root root 920 May 22 07:04 0019_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:33 0020_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:37 0021_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:39 0022_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:41 0023_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:42 0024_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:42 0025_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:45 0026_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 15:50 0027_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 17:05 0028_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 17:31 0029_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 17:33 0030_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 17:36 0031_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 17:50 0032_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 17:53 0033_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 18:27 0034_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 18:40 0035_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 18:46 0036_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 18:48 0037_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 19:08 0038_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 14 19:09 0039_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 15 07:25 0040_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 15 07:40 0041_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 15 07:51 0042_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 15 07:52 0043_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 15 07:55 0044_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 15 08:04 0045_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:20 0046_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:23 0047_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:27 0048_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:34 0049_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:35 0050_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:44 0051_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:45 0052_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 16 09:51 0053_csr-certbot.pem
-rw-r–r--. 1 root root 920 Aug 19 09:03 0054_csr-certbot.pem
/etc/letsencrypt/keys:
total 228
drwx------. 2 root root 4096 Aug 19 09:03 .
-rw-------. 1 root root 1704 May 20 13:02 0000_key-certbot.pem
-rw-------. 1 root root 1704 May 20 13:24 0001_key-certbot.pem
-rw-------. 1 root root 1704 May 20 13:25 0002_key-certbot.pem
-rw-------. 1 root root 1704 May 20 13:28 0003_key-certbot.pem
-rw-------. 1 root root 1704 May 20 13:40 0004_key-certbot.pem
-rw-------. 1 root root 1704 May 20 13:45 0005_key-certbot.pem
-rw-------. 1 root root 1704 May 20 14:18 0006_key-certbot.pem
-rw-------. 1 root root 1704 May 20 14:20 0007_key-certbot.pem
-rw-------. 1 root root 1708 May 20 14:22 0008_key-certbot.pem
-rw-------. 1 root root 1708 May 20 14:28 0009_key-certbot.pem
-rw-------. 1 root root 1704 May 20 15:33 0010_key-certbot.pem
-rw-------. 1 root root 1704 May 20 18:50 0011_key-certbot.pem
-rw-------. 1 root root 1704 May 20 18:52 0012_key-certbot.pem
-rw-------. 1 root root 1708 May 20 18:54 0013_key-certbot.pem
-rw-------. 1 root root 1704 May 20 19:01 0014_key-certbot.pem
-rw-------. 1 root root 1704 May 20 19:46 0015_key-certbot.pem
-rw-------. 1 root root 1708 May 20 20:18 0016_key-certbot.pem
-rw-------. 1 root root 1708 May 21 08:08 0017_key-certbot.pem
-rw-------. 1 root root 1704 May 21 11:17 0018_key-certbot.pem
-rw-------. 1 root root 1708 May 22 07:04 0019_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:33 0020_key-certbot.pem
-rw-------. 1 root root 1708 Aug 14 15:37 0021_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:39 0022_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:41 0023_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:42 0024_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:42 0025_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:45 0026_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 15:50 0027_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 17:05 0028_key-certbot.pem
-rw-------. 1 root root 1708 Aug 14 17:31 0029_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 17:33 0030_key-certbot.pem
-rw-------. 1 root root 1708 Aug 14 17:36 0031_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 17:50 0032_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 17:53 0033_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 18:27 0034_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 18:40 0035_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 18:46 0036_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 18:48 0037_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 19:08 0038_key-certbot.pem
-rw-------. 1 root root 1704 Aug 14 19:09 0039_key-certbot.pem
-rw-------. 1 root root 1708 Aug 15 07:25 0040_key-certbot.pem
-rw-------. 1 root root 1704 Aug 15 07:40 0041_key-certbot.pem
-rw-------. 1 root root 1704 Aug 15 07:51 0042_key-certbot.pem
-rw-------. 1 root root 1704 Aug 15 07:52 0043_key-certbot.pem
-rw-------. 1 root root 1704 Aug 15 07:55 0044_key-certbot.pem
-rw-------. 1 root root 1704 Aug 15 08:04 0045_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:20 0046_key-certbot.pem
-rw-------. 1 root root 1708 Aug 16 09:23 0047_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:27 0048_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:34 0049_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:35 0050_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:44 0051_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:45 0052_key-certbot.pem
-rw-------. 1 root root 1704 Aug 16 09:51 0053_key-certbot.pem
-rw-------. 1 root root 1704 Aug 19 09:03 0054_key-certbot.pem
/etc/letsencrypt/live:
total 8
drwx------. 3 root root 37 May 21 11:17 .
drwxr-xr-x. 2 root root 110 May 22 07:08 esmc.rta.lv
-rw-r–r--. 1 root root 740 May 21 08:08 README
/etc/letsencrypt/live/esmc.rta.lv:
total 8
drwxr-xr-x. 2 root root 110 May 22 07:08 .
drwx------. 3 root root 37 May 21 11:17 …
lrwxrwxrwx. 1 root root 40 May 22 07:05 cert.pem -> …/…/archive/esmc.rta.lv-0001/cert1.pem
lrwxrwxrwx. 1 root root 41 May 22 07:05 chain.pem -> …/…/archive/esmc.rta.lv-0001/chain1.pem
-rw-r–r--. 1 root root 3901 May 22 07:08 esmc.rta.lv.jks
lrwxrwxrwx. 1 root root 45 May 22 07:05 fullchain.pem -> …/…/archive/esmc.rta.lv-0001/fullchain1.pem
lrwxrwxrwx. 1 root root 43 May 22 07:05 privkey.pem -> …/…/archive/esmc.rta.lv-0001/privkey1.pem
-rw-r–r--. 1 root root 692 May 21 11:17 README
/etc/letsencrypt/renewal:
total 12
drwxr-xr-x. 2 root root 57 May 22 07:05 .
-rw-r–r--. 1 root root 579 May 21 11:17 esmc.rta.lv-0001.conf
-rw-r–r--. 1 root root 554 May 22 07:05 esmc.rta.lv.conf
/etc/letsencrypt/renewal-hooks:
total 4
drwxr-xr-x. 5 root root 40 May 20 12:56 .
drwxr-xr-x. 2 root root 6 May 20 12:56 deploy
drwxr-xr-x. 2 root root 6 May 20 12:56 post
drwxr-xr-x. 2 root root 6 May 20 12:56 pre
/etc/letsencrypt/renewal-hooks/deploy:
total 0
drwxr-xr-x. 2 root root 6 May 20 12:56 .
drwxr-xr-x. 5 root root 40 May 20 12:56 …
/etc/letsencrypt/renewal-hooks/post:
total 0
/etc/letsencrypt/renewal-hooks/pre:
total 0
Have you modified or deleted any of the files in /etc/letsencrypt/
? - as I remember - no, except changes possibly made by script
