Lets encypt dry run problem
this morning i had a email saying that my cert will expire in 20 days how ever i did have a cronjob to renew its been fine for 6 months but now all of a sudden im having a problem. i ran a dry run command and the output i get is this,
jack@mail:/etc/cron.d$ sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/mail.violetdragonsnetwork.co.uk.conf
http-01 challenge for mail.violetdragonsnetwork.co.uk
Waiting for verification…
Attempting to renew cert (mail.violetdragonsnetwork.co.uk) from /etc/letsencrypt/renewal/mail.violetdragonsnetwork.co.uk.conf produced an unexpected error: Failed authorization procedure. mail.violetdragonsnetwork.co.uk (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://mail.violetdragonsnetwork.co.uk/.well-known/acme-challenge/-f5lX2JGKan5cNf5X-tAzlgZdpE8sMsuagf2bNkaA2M: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/mail.violetdragonsnetwork.co.uk/fullchain.pem (failure)
    Domain: mail.violetdragonsnetwork.co.uk
    Type: connection
    Detail: Fetching
  • Your account credentials have been saved in your Certbot
any ideas?
Thanks.
Hi @violetdragon92
there
is your problem - timeout.
Checking your domain there is no open port 80 - https://check-your-website.server-daten.de/?q=mail.violetdragonsnetwork.co.uk
81.150.180.216 -14 10.030 T
Timeout - The operation has timed out
https://mail.violetdragonsnetwork.co.uk/
81.150.180.216 200 3.724 B
small content:
http://mail.violetdragonsnetwork.co.uk/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
81.150.180.216 -14 10.007 T
Port 80 must be open, the webserver must answer.
Fatal: Check of /.well-known/acme-challenge/random-filename has a timeout. Creating a Letsencrypt certificate via http-01 challenge can't work. You need a running webserver (http) and an open port 80. If it's a home server + ipv4, perhaps a correct port forwarding port 80 extern ⇒ working port intern is required. Port 80 / http can redirect to another domain port 80 or port 443, but not other ports. If it's a home server, perhaps your ISP blocks port 80. Then you may use the dns-01 challenge.
Hi thanks for your reply. I have a business line. Port 80 is open and not blocked. I only have lets encrypt for my mail.violetdragonsnetwork.co.uk which has roundcube open. I use Roundcube for my mail server. What should i do? My name servers are on DO pointing to my static IP then port forwarding my mail server for 587 and port 25 is open. Port 80 is also port forwarded for RoundCube.
Thanks for your reply
Something's blocking it, if indeed there's any process listening there in the first place. Port 443 answers, but port 80 does not.
Ok thanks guy. I will check port forwarding on my pfsense firewall.
If your port 80 is open, the online tool must be able to connect your website.
An internal connect isn't relevant.
Screenshot%20from%202019-09-05%2015-26-59
I am defiantly port forwarding so what else could be the problem?
Update. i had to change /etc/network/interfaces. Can you check now?
@violetdragon92 https://mail.violetdragonsnetwork.co.uk/mail/ has a shiny new certificate! Looks good from here!
How can you tell? im still getting this error tho, its wierd how it was working but now its not.
My mistake. Sorry. I may have read over your actual issue. However, https://mail.violetdragonsnetwork.co.uk/mail/ is accessible from my location and the certificate is valid until September 24, 2019. (dry-run issue not withstanding)
i know. But the problem is i cant renew the certificate and i had a email this morning saying that its due to expire. i dunno what to do as i cant renew it.
Fix your firewall, or your ISP's firewall. Something is blocking port 80, and until you identify and resolve that, you won't be able to obtain a cert this way.
thats the thing all ports are open on my firewall ive also verified that port 80 is also open on my mail server there is something else that is causing this.
The possibilities are limited:
  • Your ISP is blocking port 80
  • Your router/firewall is blocking port 80
  • A firewall on your server is blocking port 80
I think that's an exhaustive list. The fact remains that port 80 on your server isn't responding to external queries--not for me, not for @JuergenAuer's web tool, and not for the Let's Encrypt servers. This can only be a problem with your network. Until you find it and fix it, you won't be able to use HTTP validation to obtain (or renew) a cert.
That's the reason I've created the "check-your-website" tool. It's required to use online tools to check such things, not only local checks.
And as @danb35 wrote: If the online tool can't connect your port 80, Letsencrypt can't connect your server -> you can't create a certificate via http validation.
PS: You can always use --manual and dns-validation, if you are able to create own TXT entries. So you can create a certificate. But if you want to automate it, then http validation is the easiest version -> a working port 80 is required.
Port 80 is not working on the Server. im not sure where to go from here.
Then create a vHost.
Nginx -> there is a standard documentation + template you can use.
