Let's encrypt not working for pritunl
My domain is: hvtdc.org
My web server is (include version): running pritunl version 1.29.2664.67
The operating system my web server runs on is (include version): ubuntu 18.04 (bionic reaver
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): version 1.16.0
So my pritunl server is up and running, the DNS records are updated and resolving but when I try to connect a user to the server it times out due to a let's encrpyt error on the domain. Ive ran certbot but the machine says something else is bound to port 80 which is believe is attached to pritunl already.
Here is a screenshot of the pritunl log
Any insight as to what could be causing this would be greatly appreciated.
Pritunl seems to be shipping a build-in client, probably based on acme_tiny. So certbot isn't used at all.
Unfortunately, the log you're showing is only saying that something with the challenge didn't pass, not why.. Isn't there more information in the pritunl log?
Here is a better shot of what happens when I do try to connect to our own domain.
Unfortunately, it's not giving more information about why the challenge is failing.
are there some commands I can run on the server to display more useful data that would help?
I'm not familiar with pritunl, maybe you could check its documentation?
You could show the vhost config section/file that serves that domain name.
You could also show more detail to the command run.
You could also confirm the external IP matches the current DNS resolve for hvtdc.org.
